save_jeff
XBMC on Raspbian wheezy (install error)
Thu Sep 27, 2012 9:01 am
Hallo Board Members ;]
I'm using the latest image of wheezy (2012-09-18)
I want to install xbmc because omxplayer to simple is. but when i do so i get errors :
[email protected] ~ $ sudo apt-get install xbmc
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 xbmc : Depends: xbmc-bin (>= 2:11.0~git20120510.82388d5-1) but it is not installable
        Depends: xbmc-bin (< 2:11.0~git20120510.82388d5-1.1~) but it is not installable
        Recommends: python-qt3 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Is this an bug ? or did i forget to install something ?
cditty
Re: XBMC on Raspbian wheezy (install error)
Fri Sep 28, 2012 3:07 pm
I'm having the same problem.
notarat
Fri Sep 28, 2012 3:22 pm
If you're looking for XBMC on Pi have you tried Xbian yet?
I admit I like booting up to the command prompt first, then loading X more than booting to XBMC straight away, but at least with Xbian I can ssh into it from my other machine sitting next to it if I need to run commands
save_jeff
Fri Sep 28, 2012 7:24 pm
That s a good idea. But i want a full operating system optimized for speed and usage (apache2 mysql samba) with xbmc as an application. And xbian is optimized for xbmc.
I want to use the latest version of debian (wheezy)
A started an other thread because i tryed RaspbianXBMC
nIerSify
Thu Oct 11, 2012 11:32 am
save_jeff wrote:Hallo Board Members ;]
to correct this problem just deinstall xbmc and try to correct your dependencies. After you have installed all required libraries you should be able to install xbmc.
I had the same problem and fixed it that way....
Best regards
nIerSify
http://selfprogramming.bplaced.net
save_jeff
Thu Oct 11, 2012 11:54 am
Ok, but how do i 'try to correct [...] dependencies' and 'install all required libraries'?
What commands do i have to use ?
nIerSify
Thu Oct 11, 2012 3:50 pm
save_jeff wrote:Ok, but how do i 'try to correct [...] dependencies' and 'install all required libraries'?
If you use one of my versions, for example: https://sourceforge.net/projects/selfpr ... b/download
You can follow this guide for the installation process:
sudo apt-get update
sudo apt-get install libplist1 libmicrohttpd10 libtinyxml2.6.2 libyajl2 libssh-4
libmysqlclient18 liblzo2-2 libfribidi0 libcurl3-gnutls liblockdev1 libpcrecpp0
sudo dpkg -i xbmc-20120917_1rpb-1_armhf.deb
To start it use either the script located here: http://selfprogramming.bplaced.net/inde ... /comments/
or just type: sudo /usr/lib/xbmc/xbmc.bin
Best regards
nIerSify
save_jeff
Sat Oct 13, 2012 7:28 pm
Thank u for the answer. I will try this son. But i'm afraid because the last time it corupted the hole System and apt-get was complety messed up.
save_jeff
Sat Oct 13, 2012 7:52 pm
i installed all the libarys and that worked fine but at the line
sudo dpkg -i xbmc_20121004-1_armhf.deb
it gave me that code :
Selecting previously unselected package xbmc.
(Reading database ... 65821 files and directories currently installed.)
Unpacking xbmc (from xbmc_20121004-1_armhf.deb) ...
dpkg: dependency problems prevent configuration of xbmc:
 xbmc depends on liblzo2-2; however:
  Package liblzo2-2 is not installed.
 xbmc depends on libfribidi0; however:
  Package libfribidi0 is not installed.
 xbmc depends on liblockdev1; however:
  Package liblockdev1 is not installed.
dpkg: error processing xbmc (--install):
 dependency problems - leaving unconfigured
Processing triggers for hicolor-icon-theme ...
Processing triggers for desktop-file-utils ...
 xbmc
save_jeff
Sat Oct 13, 2012 8:13 pm
Then i installed :
liblzo2-2 , libfribidi0 and liblockdev1
Then it worked but after using
i got this error :
[email protected] ~ $ sudo /usr/lib/xbmc/xbmc.bin
/usr/lib/xbmc/xbmc.bin: error while loading shared libraries: libpcrecpp.so.0: c                                      annot open shared object file: No such file or directory
What do i do know ?
north3221
Tue Nov 20, 2012 9:45 pm
save_jeff wrote:Then i installed :
i got this error :
What do i do know ?
Not sure if you solved this? What is it in Rasbian you are after? You could do what I did, see here:
http://www.raspberrypi.org/phpBB3/viewt ... 35&t=23051
StReSsCoOl
Tue Jan 29, 2013 2:17 am
simply install libpcrecpp0 with "sudo apt-get install libpcrecpp0"
sluysen
Thu Apr 11, 2013 5:59 pm
I am going to give this a bump hence i'm stuck with the same error's
I received my Pi today. I have put wheezy on it. And now i'm trying to get XBMC on it aswell.
it should be just sudo apt-get install xbmc but it's not working.
The step's i have done so far:
sudo apt-get update (and dist-update and so one)
Then the last step: sudo dpkg -i xbmc-20120917_1rpb-1_armhf.deb gives me an errormessage:
dpkg: error processing xbmc-20120917_1rpb-1_armhf.deb (--install):
cannot access archive: No such filke or directory
It seems that this file is gone. what should I use to get xbmc running?
Return to “Media centres”
