Page 2 of 2
Re: Headless Squeezeplay on RPI
Posted: Wed Oct 03, 2012 10:47 am
by truehl
Gordian2 wrote:you can alternatively download and try an image we have created for Raspberry, using Raspbian, LMS and Squeezeplay.
[mod deleted link]
BTW, tried to contact Thomas weeks ago to share our work but got no reply
Send a PM to you!
Posted: Wed Oct 03, 2012 10:59 am
by truehl
[mod deleted link]
I yust saw that your are new to the forum so you can not read PMs I fear! So I post it open, because it's urgent:
I have not seen, that you want to contact me, sorry if I have missed something. I would like to share my project with some other very much!
One quick hint: You should not share an image with pre-installed LMS. This contains firmware for the players not owned by Logitech and only Logitech is allowed to distribute! I would like to talk to you, maybe over Skye or so!
Posted: Wed Oct 03, 2012 11:02 am
by Gordian2
PMs are ok even if you are new :) Sent you my email
Posted: Wed Oct 03, 2012 1:30 pm
by Robbe
[Mod deleted link at posters request]
Hi Gordian2,
I downloaded your image, thank you for that!
One question: what login and password do i need to use to log-in to the image?
Thanks!
Posted: Wed Oct 03, 2012 4:52 pm
by mba
truehl wrote:O.K. got it working with the very friendly help of MBA. But there are some issues:
1. Sound get's stuttering after a few minutes (internal analogue output)
2. How to configure it without a monitor connected on first start?
3. How can I start it on system boot?
4. How can I run it in background?
5. How can I shut it down and how can I restart?
By the way, the video output from SqueezePlay without X installed looks great.
And one other information: SqueezePlay is under BSD license, so we are free to use, change and distribute it! If the problems could be fixed, RPI with a touch screen could be a great SqueezeBox player!
Have fun,
Thomas
2. All configuration is stored in ~/.squeezeplay/settings/*.lua files after doing the setup in the UI, I guess it will be possible to generate the content of these files based on user input in a setup environment like the one SqueezePlug starts with. The info stored in the files are language, mac- and ip address.
5a. Starting it through xvfb-run it is possible to kill and restart it from the commandline. It will not suffer from the problem that it cannot be restarted as it does if started normally without xvfb-run where SDL is keeping the framebuffer open (or something).
5b. When starting it normally without xvfb-run (I guess you have a display) you can just navigate to the 'Quit' item in the menu.
The major problem is the dropouts in audio. I have narrowed it down to a snd_pcm_wait call that doesn't seem to return before the timeout elapses. But I need someone with insight into the bcm2835 alsa driver to debug the problem further.
Posted: Wed Oct 03, 2012 7:32 pm
by t1ger
Have fun,
Thomas
It would be fairly easy to create a script (xvfb-run) to start stop restart
based on "ps -A, kill xx" and pu it in /etc/init.d/squeezeplay
like you say MBA
And I do recommend to buy a pcm2704 based usb dac it cost about 15$ ibcluding shipping on ebay.
The built in sound is only using 11 bits, it is quite bad sound quality.
Posted: Thu Oct 04, 2012 5:28 pm
by mba
For my primary setup I'm using HDMI so no degradation of quality there. Even for my secondary project building a kitchen RPi based Squeezeplayer radio should the builtin analog audio do just fine.
Posted: Fri Oct 05, 2012 6:41 am
by Gordian2
Hi Gordian2,
Thanks!
Hi
Sorry for my late reply
login : pi
pw : root
Cheers
Posted: Fri Oct 05, 2012 7:26 am
by Robbe
Gordian2 wrote: Hi
login : pi
pw : root
Cheers
Thanks! :-)
So how do i start squeezeplay with this image? I can't find the executable..
Posted: Fri Oct 05, 2012 7:36 am
by Gordian2
for test : /opt/squeezeplay/bin/squeezeplay.sh
for real : /opt/squeezeplay/bin/squeezeplay.sh &
the difference is that you can close your ssh window with the second one
you might need to change to your IP adress in there :
~/.squeezeplay/userpath/settings/Playback.lua
to see your Squeezeplay in your LMS
keep us posted !
Posted: Sat Oct 06, 2012 5:23 am
by Gordian2
any news Robbe ?
Posted: Sun Oct 07, 2012 12:13 pm
by sbp
Hi Gordian 2
I tried to use your large rasp-logitech image.
It is starting fine, the Logitech Media Server (LMS) is starting fine, however, Squeezeplay is not starting - and trying to start it via SSH by this command results in:
pi@raspberrypi ~ $ /opt/squeezeplay/bin/squeezeplay.sh
xvfb-run: error: Xvfb failed to start
Regards
Posted: Mon Oct 08, 2012 6:55 am
by Gordian2
Hi sbp,
Try just to reboot it
Posted: Mon Oct 08, 2012 1:10 pm
by Robbe
Gordian2 wrote:any news Robbe ?
Hi Gordian2,
I still have to try it, I am moving to another house so I didn't have the time yet to try it.. but I have a good feeling about it! :-)
As soon as I find the time to try it, I'll let you know!
Posted: Mon Oct 08, 2012 7:14 pm
by t1ger
sbp wrote:Hi Gordian 2
Regards
In squeezeplay.sh is there a -a after xvfb-run
xvfb-run -a ./jive
Posted: Thu Oct 18, 2012 6:57 pm
by mba
With the latest firmware I have now played flawless internet radio for 5+ hours using the following /etc/asound.conf
pcm.!default {
  type hw
  card 0
No stutter and no freezes.
Posted: Sat Oct 20, 2012 4:36 pm
by t1ger
Hi
Has anyone figured out how to add libspotify to squeezeplay (not to LMS)
I have added the libspotify to /usr/lib but when squeezeplay start the log output says that spotify is disable. I have also tryid libspotify v6 that runns on squeezebox radio.
I have spotify running on the LMS so i have spotify support, but it would be nice to have it in the squeezeplay app to.
Posted: Sat Oct 20, 2012 7:31 pm
by mba
t1ger wrote:Hi
You can follow some of the spotify-related steps in my previous post here.
Posted: Sun Oct 21, 2012 1:48 pm
by t1ger
mba wrote:
t1ger wrote:Hi
Hi the Triode uses the LMS for handling spotify.
The Logitech spotify support uses the squeezeplay for playback of spotify.
If the libspotify is not working during squeezeplay start you will have this message
audio.decode - SpotifyMeta.lua:27 Spotify decoder not available, disabling Spotify support
If squeezeplay recognize the lib the Logitech official app will work.
On the squeezebox radio libspotify.so.6 is located in /usr/lib
the libspotify for armel is found here
https://developer.spotify.com/technolog ... /#download
use eabi-armv6t
Posted: Sun Oct 21, 2012 6:00 pm
by mba
t1ger wrote:
mba wrote:
t1ger wrote:Hi
use eabi-armv6t
As far as I know the official Spotify plugin only supports the SqueezeBox radio and Touch. The third party plugin by Triode works on SqueezePlay and other players as well.
Posted: Tue Oct 23, 2012 9:59 am
by pbattino
it works, but only on a "soft-float" (armel) Debian, not on the latest hard-float. AFAIK, there is no way of having the plug-in by Triode working on a hard-float distro, simply because there's no libspotify compiled for Arm hard-float. The guys at Spotify are not really helpful on that.
PS: I have tried that setting (SqueezePlay + spotify) on a soft-float and was not really happy: sound often choppy as if the RPI was too busy, even if there was nothing else running and no X running. I abandoned that solution.
