Something simple (like bob) is possible. Could you provide a sample file that would benefit from this?sugatam wrote:Is there a possibility of adding this to the GPU? Doesn't have to be fancy, even bob would do.
Thanks.sugatam wrote:Here is a clip from NBC captured using my hdhomerun. It is 1080i mpeg2 with ac3 audio, and the pi plays it perfectly other than the jaggies.
https://docs.google.com/open?id=0B6kbH3 ... mZJRG8yMWc
I've added a simple "bob" deinterlace to GPU that seems to work akay at 1080i.sugatam wrote:Here is a clip from NBC captured using my hdhomerun. It is 1080i mpeg2 with ac3 audio, and the pi plays it perfectly other than the jaggies.
Yes, rpi-update or grab start.elf from GitHub.sugatam wrote:Wow, that was fast! Thanks dom!! I compile my own omxplayer, so I can remove the check easily enough myself. Do I need a new firmware?
You don't want to do that. It will apply the algorithm and degrade the quality of progressive content.sugatam wrote:Just tested it - works great! Thanks a lot!! Hopefully one of days you'll have the time to code something a more sophisticated deinterlacing algorithm, but this is great in the meantime.
BTW, is there any harm to calling omxplayer with -d even when the source is progressive? Hopefully the GPU does not do anything if it is dealing with progressive content?
I believe this will work with a recent xbmc build.sorrowuk wrote:If I update to this latest gpu firmware and also use the latest nightly xbmc build can I deinterlace 1080i using bob.
Do I just select the deinterlace option in xbmc and will it work ? Can I expect it to run at 50fps with no drop frames ?
We can do weave...sorrowuk wrote:Is bob the best deinterlacing the pi can do ?
Is everything else too too powerful for the processor/gpu ?
I just downloaded the latest Raspian SD card image (end of October 2012) after waiting all month and am disappointed this 1080i bob deinterlacing feature is not included in omxplayer. I guess an older version of omxplayer is still included with official Raspian release?dom wrote:I've added a simple "bob" deinterlace to GPU that seems to work akay at 1080i.
Should be supported in a build soon...
What memory split are you on? Can you try with 128M on GPU?Huffster wrote:I tried to install different and newer binary versions of omxplayer that others built, but the screen just goes black when trying to use the -d option on 1080i material. The concert rips sound MUCH better with these different versions though.
