fkbreitl
DVB-T2 TV with Raspberry Pi 3?
Tue Apr 18, 2017 10:30 pm
I would like to watch the German terrestrial TV broadcast (DVB-T2) with my Raspberry Pi 3.
I have bought a Geniatech T230C and could receive HD channels with Tvheadend 4.2 in LibreELEC 8.0.1.
However, the playback stutters, the audio gets asynchronous and after about 30 seconds some sort of reload happens. Moreover the stream stops after some time. Since there is also the hot CPU warning despite my open case and heat sinks it looks like currently the system is not able to decode the H.265 / HEVC stream in real-time.
Now I am wondering if there is any chance of viewing German terrestrial TV with a Raspberry Pi becoming possible for example through advances in the decoding libraries or through hardware decoding support by USB sticks or if one should not expect this to happen.
Re: DVB-T2 TV with Raspberry Pi 3?
Tue Apr 18, 2017 10:37 pm
fkbreitl wrote:I would like to watch the German terrestrial TV broadcast (DVB-T2) with my Raspberry Pi 3.
H265 is not supported:
viewtopic.php?f=38&t=123876&p=1108319&h ... 5#p1108319
viewtopic.php?f=63&t=167812&p=1080080&h ... 5#p1080080
viewtopic.php?f=38&t=140356&p=930198&hilit=H265#p930166
adieu
My other Computer is an Asus CS10 ChromeBit
gregeric
Tue Apr 18, 2017 11:16 pm
H265 is/will be suppoorted, but not at the highest resolution/framerate:
viewtopic.php?f=63&t=156434&p=1112221#p1129848
fkbreitl
Tue Apr 18, 2017 11:42 pm
Excellent! And how can one get this working on Raspbian?
gkreidl
Wed Apr 19, 2017 6:25 am
fkbreitl wrote:Excellent! And how can one get this working on Raspbian?
You can't. All new German DVB-T2 channels use H265 1920p50 and that is simply too high for the RPi.
Satellite and Cable TV run fine, as they are all using H264 (and MPEG2 for most SD channels).
Minimal Kiosk Browser (kweb)
Wed Apr 19, 2017 10:37 pm
The Asus Tinker Board supports H265 afaiaa: https://www.asus.com/uk/Single-Board-Co ... /overview/
adieu
HiroProtagonist
Thu Apr 20, 2017 11:36 pm
You can't view h265 real-time.
You can record h265 and post-process the files to something the Pi can display. Probably better to do this on a separate device to the one you're using as the front-end.
odoy
Mon Jun 11, 2018 5:41 pm
hi, where does the hevc encoding executed?
my plan is to install tvheadend server on a rpi3, attach a Geniatech T230 stick and to watch the streams on hardware which can encode x265 codec like odroid c2 and newer iOS devices.
does the encoding happens on the server or on the client side?
thx
gkreidl
Mon Jun 11, 2018 6:09 pm
thx
decoding, not encoding, happens on client side.
odoy
Tue Jun 12, 2018 9:45 am
oh yes you are right. decoding :D
danke!
Return to “Media centres”
