teeth_03
Dual boot XBMC and Raspbian?
Tue Sep 18, 2012 11:13 am
Basically, i want to setup my SD card so when you boot it up, you select Raspbian (Desktop interface) or XBMC from a boot menu. I dont want it to auto boot into anything.
Do any of the 3 XBMC distros have this as an option? XBMC is great and all, but i would still like access to the desktop interface.
If none of them have an option, could i install one and change the boot settings? If so, which one would work?
JeremyF
Re: Dual boot XBMC and Raspbian?
Tue Sep 18, 2012 11:19 am
The easiest way would be to just install XBMC in Raspbian: http://www.raspberrypi.org/phpBB3/viewt ... 66&t=12455
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
caravela
Tue Sep 18, 2012 12:25 pm
i have never tried it myself but you could take a look at http://www.berryterminal.com/doku.php/berryboot
teeth_03
Tue Sep 18, 2012 5:37 pm
Berryboot breaks my wifi
And im still in the process of getting xbmc installed in rasbian...
woodland
Fri May 01, 2015 4:08 pm
What is the difference between XBMC and Raspbian ?
C-Fu
Sun May 03, 2015 6:33 pm
I did this by
1. Install Raspbian
2. Install RetroPie
3. under RetroPie-Setup, I installed Kodi
4. Made RetroPie boot automatically (instead of Raspbian/startx)
5. Under EmulationStation, you can select Raspbian or Kodi (or DosBox or any of the emulators)
This is the best way IMO. Another way would be to use either BerryBoot, or NOOBS (OpenElec + Raspbian).
Return to “Media centres”
