apoth
Terminal visible outside XBMC video letterbox
Sun Sep 16, 2012 12:03 pm
My XBMC menus fill my 16:9 screen, but some films display in a letterbox.
In the black regions above and below the video I can see the terminal output behind. XBMC is started via the init.d service script that's floating around the forums so I don't think the 'clear' hack works - or at least I can find where to put it to make it work.
Any suggestions? Thanks in advance.
sunstriker
Re: Terminal visible outside XBMC video letterbox
Fri Oct 12, 2012 3:42 pm
Same issue here
j0nnymoe
Fri Oct 12, 2012 3:53 pm
In the video Playback settings in XBMC, tell XBMC how to handle your 4:3 Videos, If you stretch to 16:9, That will fill your screen.
RPi[1]: Arrived 5/7/12 | RPi[2]: Arrived 10/7/12
PSN/XBL: m0euk
SGS3 i9305: CyanogenMod10.1 Nightlies
esuz
Thu Dec 13, 2012 2:16 pm
Unfortunately, that doesn't fix it. Console still visible.
Any other ideas?
Casty
Fri Dec 14, 2012 4:05 am
I had the same issue when I was running a compiled version of XBMC on top of my Raspbian version. I started using Xbian instead and I did not have the same issue. RaspbMC probably fixes it as well but I haven't used that.
Return to “Media centres”
