Installing Logitech Media Server in Raspbmc
Posted: Sat Sep 15, 2012 5:43 pm
by rock_rebel
Is there a way to install Logitech Media Server in Raspbmc, and still be able to use the traditional Squeezeplayer remote for iPhone/Android as well as gain remote access to the server interface?
Re: Installing Logitech Media Server in Raspbmc
Posted: Sun Sep 16, 2012 4:06 pm
by elatllat
likely yes as you can get the perl source code http://downloads.slimdevices.com/Logite ... -7.7.2.tgz
Posted: Mon Sep 17, 2012 9:56 pm
by kodess
Squeezeplug has an image for a raspberry pi on their website:
http://squeezeplug.de/
The creater also hangs around on the forums here, so if you need help, he'll probably reply :P
And yes it works exactly like LMS
Posted: Thu Sep 20, 2012 2:18 pm
by salts633
If you want to compile LMS from source look at this post http://www.raspberrypi.org/phpBB3/viewt ... 35&t=15555. The instructions are for straightforward raspbian but I presume its not too much difference for raspmc. If you're not worried about the spotify plugin you can install LMS in the armhf version and it works pretty much flawlessly.
Posted: Fri Sep 21, 2012 1:51 pm
by rock_rebel
Thanks for all the great help. I'll be sure to try Squeezeplug out!
