rock_rebel
Installing Logitech Media Server in Raspbmc
Sat Sep 15, 2012 5:43 pm
Is there a way to install Logitech Media Server in Raspbmc, and still be able to use the traditional Squeezeplayer remote for iPhone/Android as well as gain remote access to the server interface?
elatllat
Re: Installing Logitech Media Server in Raspbmc
Sun Sep 16, 2012 4:06 pm
likely yes as you can get the perl source code http://downloads.slimdevices.com/Logite ... -7.7.2.tgz
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
kodess
Mon Sep 17, 2012 9:56 pm
Squeezeplug has an image for a raspberry pi on their website:
http://squeezeplug.de/
The creater also hangs around on the forums here, so if you need help, he'll probably reply :P
And yes it works exactly like LMS
salts633
Thu Sep 20, 2012 2:18 pm
If you want to compile LMS from source look at this post http://www.raspberrypi.org/phpBB3/viewt ... 35&t=15555. The instructions are for straightforward raspbian but I presume its not too much difference for raspmc. If you're not worried about the spotify plugin you can install LMS in the armhf version and it works pretty much flawlessly.
rock_rebel
Fri Sep 21, 2012 1:51 pm
Thanks for all the great help. I'll be sure to try Squeezeplug out!
Return to “Media centres”
