Boomer
Squeeze Box Player
Fri Sep 14, 2012 2:05 am
Using this link (www.squeezeplug.de) (THANK YOU!!!), I got my Raspberry Pi working as a Squeezebox tonight. I'm able to stream Pandora and other internet music services. Once I take care of some file management, I believe it will play my music files as well. Pretty slick. I may be half deaf, but it sounds pretty good through my TV. Plan to hook it up to a DAC and run it through my stereo tomorrow. Not bad. A Squeezebox Touch costs around $300 here in the US so a $35 Pi and some peripherals seems like a pretty good deal.
Only disappointment is that I couldn't easily configure a wifi connection. I'm a little leery of trying to run Mr.Engman's script even though it worked like a charm on my Raspian configuration.
Any thoughts would be greatly appreciated.
castalla
Re: Squeeze Box Player
Fri Sep 14, 2012 8:19 am
There are two other threads about squeezeplug on this forum.
Check those out.
MrEngman's script worked for me with the Edimax wifi dongle.
alexeames
Fri Sep 14, 2012 7:00 pm
Boomer wrote:I'm a little leery of trying to run Mr.Engman's script even though it worked like a charm on my Raspian configuration.
Why don't you make a backup copy of your SD card and try the script on it? Then if it messes up you lose nothing. :D
Alex Eames RasPi.TV, RasP.iO
Trixster
Sat Sep 15, 2012 8:42 am
I can confirm that the MrEngman's script works perfectly with SqueezePlug, I set it up last night!
Return to “Media centres”
