Multiple Screens of 5 - 10
Posted: Thu Jan 12, 2017 10:28 pm
by Ritchievalens
Hi Folks,
I Hope I have posted to the correct group?
I have just discovered the Raspberry Pi and was wondering if there is a way to have:
1. Pi computer
2. With Multiple screens maybe 5 - 10 ( Is there a limitation of screens on 1 Pi PCB )
3. On each screen a different image or video
Is this possible and if so what is the best way to do this and what Hardware/Software do I need?
I would be so excited if this is a possibility.
Thanks a Million.
Ritchie
Re: Multiple Screens of 5 - 10
Posted: Thu Jan 12, 2017 10:48 pm
by klricks
For multiple screens you will need multiple RPi's 5 - 10
Posted: Thu Jan 12, 2017 10:54 pm
by fruitoftheloom
Ritchievalens wrote:Hi Folks,
1. Pi computer
Thanks a Million.
Ritchie
It is not easy to have multi-screens connected to a Raspberry Pi Single Board Computer.
Probably easier to use a single Raspberry Pi model Zero or A+ connected to each Screen and set up a Main Server to deliver the content.
Posted: Thu Jan 12, 2017 11:15 pm
by hippy
The VGA666 interface has 18 colour lines so they could in theory be repurposed to drive anything from one monitor through to 18 with reducing colour depth and possibly decreasing frame rates due to having to assemble a single frame buffer as a composite of all the others -
1 x 18-bit colour
2 x 9-bit colour
3 x 6-bit colour
6 x 3-bit colour
18 x 1-bit monochrome
6 x 3-bit should be acceptable for static signage type displays. I have been meaning to try it but haven't found the time to do so. One would only need a single monitor and some frame buffer filling code to test how good or poor the quality is.
That's a rather specific use case. For general purpose use it's one monitor per Pi.
Posted: Thu Jan 12, 2017 11:57 pm
by Ritchievalens
Hi Folks
Thank you for the amazing fast responses in my first post.
I will need to digest what people have suggested, and the pit falls.
Is it best to use Raspian?
Or shall I load another OS on?
If so what?
I am getting a Pi on Saturday, so I will at least get 2 working, which I hope will be straight forward.
Would it be easier to attempt this in Hardware or Software?
Hardware, maybe a video splitter or software, as in ( I have no clue )
Sorry for all the questions, but I need to know at least what direction to aim towards.
Ritchie
Posted: Fri Jan 13, 2017 12:11 am
by Ritchievalens
Hi Fruitoftheloom
Do you have any more info that you could show me please referring to " Setting up a Main Server to Deliver Content "
1. Pi computer
Thanks a Million.
Ritchie
Posted: Fri Jan 13, 2017 7:38 am
by fruitoftheloom
Ritchievalens wrote:Hi Fruitoftheloom
1. Pi computer
Thanks a Million.
Ritchie
That is a very open ended question, lots of alternatives.
One such is Plex Media Server & Client
https://www.element14.com/community/com ... berry-pi-3
http://www.rasplex.com
Posted: Fri Jan 13, 2017 3:15 pm
by drgeoff
hippy wrote:The VGA666 interface has 18 colour lines so they could in theory be repurposed to drive anything from one monitor through to 18 with reducing colour depth and possibly decreasing frame rates due to having to assemble a single frame buffer as a composite of all the others -
1 x 18-bit colour
2 x 9-bit colour
3 x 6-bit colour
6 x 3-bit colour
Have you overlooked that each monitor requires HSYNC and VSYNC in addition to the RGBs? Yes all the monitors could be fed from a single pair of HSYNC and VSYNC signals if they had enough strength but, as Gert mentioned in the manual on github, even driving one monitor is a compromise between keeping within the limit on a GPIO and getting enough sync signal voltage into the 75 ohm load of a monitor.
Posted: Fri Jan 13, 2017 3:58 pm
by hippy
drgeoff wrote:Have you overlooked that each monitor requires HSYNC and VSYNC in addition to the RGBs?
I was expecting to have to buffer HSYNC and VSYNC.
But you did drive me to re-read the docs and I rediscovered it can go all the way up to VGA888 which is better for 2 screens, provides for 4 x 6-bit and 8 x 3-bit is better than 6 x 3-bit.
Posted: Fri Jan 20, 2017 8:57 am
by Ritchievalens
Hi Folks
So in simple language, what is the best way forward?
Let say the Max will be 10 screens.
Is there any reliable Media server Software?
I have received the Pi in 2 days ago, and not 100% sure the best way forward.
Is it best to have an intelligent screens from 1 - 10 or a simple dumb terminal, with basic video capability?
Or shall I just get 10 Raspberry Pi 3's?
Any simple advice would be appreciated.
Thanks again.
Posted: Sat Jan 21, 2017 10:15 am
by aBUGSworstnightmare
Get 8 to 9 Raspberry Zeros and 2 to 1 RPi3. Have a look at Raspberry presents SW.
Posted: Sat Jan 21, 2017 10:59 am
by DougieLawson
aBUGSworstnightmare wrote:Get 8 to 9 Raspberry Zeros and 2 to 1 RPi3. Have a look at Raspberry presents SW.
Pi Presents: https://github.com/KenT2/pipresents-next
Pi Wall: http://piwall.co.uk/
Posted: Sat Jan 21, 2017 11:49 am
by jamesh
Your use case is a little unclear.
Do you want all displays to show the same video at the same time? Or can each display be doing something different?
Either way though, a Pi for each display is the best option. Either have the video stored on each Pi/SD card, or get Pi's to look at a server for the video.
Posted: Sat Jan 21, 2017 12:30 pm
by DougieLawson
Hence my pair of URLs.
PiPresents is the each RPi being a discrete server with the content on the SDCard or a USB stick.
PiWall is the central server directing the other displays over the network.
In both cases one RPi per TV/Monitor and possibly another as central controller (for PiWall) are required.
Posted: Sat Jan 21, 2017 6:27 pm
by Ritchievalens
Hi Folks
Thanks for responding.
I will download and try what has been suggested.
Basically what I would like is to have 1 Pi as a Master and 10 - 15 Pi's showing a different image or video on each screen.
1. Is the Pi up to it, because when I tried to listen to Audio through Bluetooth it was stuttering?
2. Is that a limitation of Bluetooth, would WiFi be better?
I fed a Video through HDMI to my big monitor and it kept freezing and locking up.
I have the latest Raspian.
Am I missing something, that you guys can see?
Thanks again
Ritchie
Posted: Sat Jan 21, 2017 6:30 pm
by Ritchievalens
Jamesh Thanks
I would like each screen to display a different Video or Photo.
Which would you do?
1. Look for Data on another Pi SD card or Server?
jamesh wrote:Your use case is a little unclear.
Posted: Sat Jan 21, 2017 8:09 pm
by jamesh
If videos need to be regularly updated, use a server. If they will only be changed infrequently, put them on the SD card. and save the server setup hassle.
Use Wifi. Bluetooth has limited bandwidth and range. Won't be good enough for video, perhaps good enough for a control channel.
Posted: Sat Jan 21, 2017 8:15 pm
by DougieLawson
Ritchievalens wrote: Basically what I would like is to have 1 Pi as a Master and 10 - 15 Pi's showing a different image or video on each screen.
PiWall does that.
Posted: Sat Jan 21, 2017 10:56 pm
by Ritchievalens
Thanks Guys
I will try as much as I can and if I have any questions I will ask.
I appreciate all of your advice so far
Ritchie
