CBiX
DIY YouTube TV
Tue Sep 13, 2016 12:38 pm
Play YouTube videos on your Raspberry Pi from your smartphone with the official YouTube app. Pretty much what a Chromecast or https://youtube.com/tv does, but Open Source, with less dependencies and hardware-accelerated!
I will make the following guide more user-friendly as soon as I find the time. Until then, ask or use google to solve any issues.
Please report issues on https://github.com/CBiX/gotubecast/issues, thanks!
Guide:
  • Get raspbian lite running on your Raspberry Pi
  • Install omxplayer from repo
  • Install latest youtube-dl on the Pi (the one in the repo might not work)
  • Install latest golang environment on your Pi or on your computer
  • If you installed golang on your computer, fetch the gotubecast repo and cross-compile it for the Pi, then copy the binary and the raspi.sh script onto the Pi:
    git clone https://github.com/CBiX/gotubecast
    cd gotubecast
    GOARCH=arm go build
    scp gotubecast examples/raspi.sh [email protected]:/home/pi/ # (insert your Pi's IP)
    ssh [email protected]
    sudo mv gotubecast /usr/local/bin/
    ./examples/raspi.sh
  • Otherwise, follow the build instructions in the gotubecast readme, then execute $GOPATH/src/github.com/CBiX/gotubecast/examples/raspi.sh
  • If you want, copy the displayed screen ID and copy it into the raspi.sh script so you don't have to enter the pairing code every time
  • Enter the displayed pairing code in the YouTube app under Settings → Connect to TV
Known issues:
  • youtube-dl takes ~ 10 seconds to extract the video stream URL
  • volume control doesn't work
powsniffer0110
Re: DIY YouTube TV
Fri Sep 22, 2017 8:52 am
This is EXACTLY what I and MANY MANY others have been looking for!! Thank you! Can you please explain in more simple detail how to configure the gotubecast settings and set-up?! I'm not quite sure I understand the golang environment instructions and how to cross-compile and add the binary script.
Please please get back to me with the help, and THANK YOU!! 🎉
CBiX
Re: DIY YouTube TV
Wed Aug 22, 2018 10:31 pm
Hey, thanks for the feedback, I was a bit surprised I only got approached by RasPi users because the raspi script was originally only a byproduct :D
If you are unable to compile it, you can use the precompiled RasPi version from this comment: https://github.com/CBiX/gotubecast/issu ... -340281401
gotubecast technically doesn't need any setup, however there are a few options you might check out by running
gotubecast -h
. Most relevant might be reusing the screen_id so you don't need to pair your app every time.
Good luck :)
Sanskar_85111
Re: DIY YouTube TV
Sat Jun 01, 2019 12:16 pm
I have compiled gotubecast but it shows error that is
Token parameter not in video error org.freedesktop.DBus.Error.serviceunknown
The name media player2.omxPlayer was not provided by any service file
Return to “Media centres”
