owltim
YouTube on Raspbmc
Tue Aug 28, 2012 10:53 am
Hi All,
Just got my Pi running with Raspbmc. Normal video playback works fine, as does the TED app (yay!), but the youtube app is currently being totally fail. Basically, I can browse the category tree fine, but as soon as I try to hit a leaf node, after a while of attempted loading I get a script failed error message and I'm returned to the previous screen. The same happens for searches. I get the same whether I'm logged in to youtube or not.
My searches for help on the topic have somewhat drawn a blank as all the results are youtube videos relevant to all the search terms less youtube, which is pretty much useless.
Anyone able to offer a suggestion as to how to get this working or whether it's a lost cause?
Tim
redhawk
Re: YouTube on Raspbmc
Tue Aug 28, 2012 10:59 am
What version of the plugin are you using??
YouTube works fine with OpenELEC apart from the annoying few seconds hang after finishing a clip.
Richard S.
owltim
Tue Aug 28, 2012 11:20 am
Youtube is version 3.1.0. Same problem happening with South Park 1.0.0. Also Transmission doesn't start, with a message of "Failed to connect to transmission" and then asks whether I want the settings dialog. Interestingly, I get a snatch of transmission interface before that dialog pops up.
I'll have a play with openELEC and see if that's any better.
bob_binz
Tue Aug 28, 2012 11:46 am
owltim wrote: Also Transmission doesn't start, with a message of "Failed to connect to transmission" and then asks whether I want the settings dialog. Interestingly, I get a snatch of transmission interface before that dialog pops up.
Assuming you're trying to use the transmission plug-in with transmission-daemon, be aware that the settings file you need to modify is in /etc/transmission-daemon. Had me scratching my head for ages! Make sure the RPC settings are configured correctly in the settings.json file.
Pihkal
Tue Aug 28, 2012 7:07 pm
I'd like to hear how openelec did,owltim.
Like you i'm looking for youtube support,tried xbian,did briefly work never get it to work again and i've tried raspbmc,never worked.
I'm curious if openelec's youtube support works.
Keep us posted please.
Greetz
bob_binz
Tue Aug 28, 2012 7:36 pm
YouTube (3.1.0) and iPlayer (UK only) both working fine here on Raspbmc. Searching is a little slow and has timed out occasionally, but in the main, is fine
magno23
Tue Aug 28, 2012 9:09 pm
that always happens to me, what i do is, i install the youtube addon, i make login then i restart the raspberry pi and every thing works.
i don't know why but works every time
Syrioth
Tue Aug 28, 2012 9:47 pm
I had the youtube addon crash when i was trying to use it, re-installed the addon and it seemed to work fine...
bolesk6528
Wed Aug 29, 2012 3:56 am
Got it working but what is the deal with the little pause before the video ends?
I mean I can live with it but it is just a tad annoying lol
Pihkal
Wed Aug 29, 2012 5:41 pm
My youtube is also working now.
Don't know how but it's working perfectly (using raspbmc).
Greetz
owltim
Thu Aug 30, 2012 12:16 pm
After uninstalling and reinstalling youtube, it's now working perfectly for me too.
esseti
Thu Sep 13, 2012 11:14 am
Hi.
i've rasbmc and yt plugin (3.1.0, the last).
every time i try to load some content it says: script failed.
Pihkal
Thu Sep 13, 2012 3:01 pm
It should work.
Try to re-install it,afterwords reboot your pi and try yt again.
Greetz
rock_rebel
Sun Sep 16, 2012 11:10 pm
I'm also having the same issue. I've tried both Youtube and the Wired.com add-on with no success. I've even tried a restart, but still getting the script error when I try to launch both add-ons. The Engadget add-on works fine, but the video is only playing on part of the screen.
Rain_1
Tue Sep 18, 2012 2:53 pm
YouTube 3.1.0 is busted on every platform, according to thus bug report: http://code.google.com/p/youtubexbmc/is ... tail?id=42
However, it seems somebody has managed to fix it with some clever programming: http://forum.xbmc.org/showthread.php?pi ... pid1191793
I have yet to try it on the Pi, but I can confirm that I have the same issued described by the Bug Report.
Pihkal
Tue Sep 18, 2012 11:19 pm
Hmmm...weird,youtube plugin stopped working.
I can browse but when the video should start to play it never does.
Don't get a script error,it says the item could not be played and i should check the logs.
But the log is huge and i don't really know what to look for,probably an error message of some kind.
Bummer!
Paul Webster
Contact: Twitter
Wed Sep 19, 2012 8:36 am
Have you tried the solution that is linked to in the previous posting in this thread?
Pihkal
Wed Sep 19, 2012 8:53 am
Yes and no,i've tried to install both zip-files but then i get a script-error,however this was on openelec and not raspbmc.
I still have to try them on raspbmc.
Pihkal
Wed Sep 19, 2012 12:03 pm
Sorry for the double post but i can't edit my previous post.
Anyway,the new plugin works perfectly on raspbmc.
Good job!
Thanks!
djkidy123
Thu Feb 07, 2013 5:31 pm
Can't get to login with my google accaount to youtube plugin in Rasbmc, it works normal on openelec??
Any Help here and sorry for my bad English
DamienAnton
Fri Feb 08, 2013 4:57 am
I personally recommend Xbian. The wifi support is plugin play friendly, youtube and most addons work great, and you never get that music glitch where it stops playing after so many songs.
djkidy123
Fri Feb 08, 2013 1:37 pm
I'm having xbian problem,onih with rc6 mce remote....
Return to “Media centres”
