emajko159
raspberry pi model b as NAS
Mon Aug 13, 2012 5:29 pm
i am planning buy model b.
through usb hub i connect few usb harddisk, through lan i connect raspberry to home network.
what speed will be when i will copy files from usb hdd through lan into some computer in home network?
thanks.
forenbenutzer
Re: raspberry pi model b as NAS
Mon Aug 13, 2012 6:47 pm
Not more than 30-40MB per second with a Gigabit-LAN-USB-Adapter due to the limitations of the USB port. About 10-20MB per second is somehow realistic i think.
Pitendo - Case And Emulator Project - http://edv-huber.com/index.php/problemloesungen/12-pitendo
emajko159
Mon Aug 13, 2012 6:59 pm
i need just real 10 MB/s. if it is real, so ok.
but if on one usb is ethernet adapter and hdd, then speed of one usb must be split between harddisks and ethernet. so 15MB/s for hdd and 15MB/s for ethernet (when 30MB/s is real speed of usb 2.0).
true of false?
have you rapsberry pi or you just think this?
bredman
Tue Aug 14, 2012 8:21 am
Lucky for you, there is a thread discussing exactly the question you are asking...
http://www.raspberrypi.org/phpBB3/viewt ... 36&t=13695
emajko159
Tue Aug 14, 2012 8:43 am
och. thanks. it is exactly what i need :-)
Return to “Media centres”
