galaxyrider
Osmc and raspbian
Fri Feb 12, 2016 9:17 am
Hello. I've been looking into having OSMC on my Rpi and have found that it's on the latest version of Noobs. I wondered if you can swap between it and raspbian. If so how do I do this? Thanks.
Re: Osmc and raspbian
Fri Feb 12, 2016 11:15 am
galaxyrider wrote:Hello. I've been looking into having OSMC on my Rpi and have found that it's on the latest version of Noobs. I wondered if you can swap between it and raspbian. If so how do I do this? Thanks.
If you have an Internet Connection via Ethernet when you first boot up NOOBS it will offer to install various Operating Systems.
On subsequent boot ups you will be presented with a menu to choice which OS you want:
https://github.com/raspberrypi/noobs
Thinking outside the box is better than burying your head in the sand...
drgeoff
Fri Feb 12, 2016 2:58 pm
Note that when NOOBS gives you the choice of what Operating Systems you want to install, it is a one-time choice. You cannot add another one later except by wiping the card and starting again.
DarrenHill
Fri Feb 12, 2016 3:44 pm
If you want that kind of multiple-OS set-up with a choice at boot-up, look at BerryBoot.
galaxyrider
Sat Feb 13, 2016 6:22 am
Thanks for your help. I now have raspbian and OSMC running on my Pi.
Return to “Media centres”
