Raspbmc + HDMI + standard 3.5mm jack (AUX)
Posted: Fri Aug 03, 2012 4:49 pm
by raspberrypiAndMe
Hi there,
I hope someone can help me out.
Actual condition:
- got my raspbmc up and running
- everything is fine, streaming movies with sound over HDMI to my TV
- Airplay works fine with my Android Device
I guess it's not really possible, but... :roll:
do you think there is a way to output the sound over HDMI and the standard 3.5mm jack (at the same time)?
The reason why I want to do this:
Without having the TV on, streaming music from my Android to my HiFi system.
Re: Raspbmc + HDMI + standard 3.5mm jack (AUX)
Posted: Sat Aug 04, 2012 2:16 pm
by norp
Wanted to do the same
Apparently the sound driver (alsa) is too alpha right now for dual audio.
What would work is if xbmc actually allowed to seperately set different audio device for movies and music; this won't need a proper driver support, just a small (?) software rewrite.
Unfortunately I don't have enough time to delve into the depth of the xbmc source code and this request has been queuing for ages (just check out the xbmc forums)
Posted: Thu Sep 06, 2012 4:23 pm
by raspberrypiAndMe
Hi norp,
unfortunately I also got no time to rewrite the driver and also got no experience with it.
Is there something new going on?
Posted: Mon Oct 15, 2012 6:54 pm
by captainzoom
If this were possible it would be great for the same reason as stated by OP.
Posted: Wed Dec 19, 2012 8:06 am
by Zlad
Can I ask how to set the aux > hdmi as sound? I need to do this because of the way my surround sound is set up.
Posted: Wed Dec 19, 2012 11:16 am
by captainzoom
Go to settings -> system -> audio -> output.
Posted: Mon Jan 07, 2013 9:59 am
by niomix
Hi to all, i've the same problem.
Someone solve he issue using this patch... but is't for windows only !
http://forum.xbmc.org/showthread.php?tid=86038
any new idea ?
Posted: Thu Feb 14, 2013 3:30 pm
by adamdbz
Any update i would love to use them both too. :D
Posted: Sat Jan 11, 2014 10:53 am
by adrianzhang
This was solved in the newest version RaspBMC (based on my reply time), I did something and sound go out from both HDMI and 3.5mm jack.
Posted: Sat Jan 11, 2014 4:19 pm
by niomix
yes but with a big unmodifiable delay betweek two channels :(
You can't use both at the same time yet.
Posted: Mon Jan 13, 2014 10:10 am
by adrianzhang
niomix wrote:yes but with a big unmodifiable delay betweek two channels :(
Are you replying to me? I didn't meet similar issue, sound syncs of HDMI and Stereo on my RaspBMC system.
BTW, based on my experience, this was solved by newest RaspBMC, with some configs users are able to hear sound from both HDMI and 3.5mm jack.
However, that doesn't realize on my Raspbia+XBMC(which installed by following this post: http://michael.gorven.za.net/raspberrypi/xbmc
