Douglas6 wrote:Probably your best options for playing the Pandora stream on a Raspberry Pi are:
1. Install pianobar on the Pi. No phone needed.
2. Stream your phone's audio to the Pi over Bluetooth.
I just thought, install an apk emulator in the Pi to run the same app directly from the pi may work.
I still got to wait for either the little screen, the HDMI to VGA or the HDMI to RCA adapters to arrive. I tried to visualize the pi in my laptop through Ethernet with out good results and the file I learned needs modification so putty can connect (contains the port number) is not in the distros I got. II got a composite to RCA cable but I can't press #3 for my pi to switch to the composite video/audio output since the only keyboard I got has to be installed first and I can't see a thing.
I'm just sad I have not been able to do a thing yet.
