Page 12 of 25
Re: XBian - Small, Fast, Lightweight XBMC solution
Posted: Mon Aug 13, 2012 11:06 am
by pin00b
hi,
just loaded the latest release 0.6
pretty slick.
i think this is the fastest so far out of openelec and raspbmc
the big problem i have is trying to use my mce remote doesn't work, i can move left to right and some other buttons. but the majority of the buttons don't work. e.g. select.
anybody else having this problem?
Posted: Mon Aug 13, 2012 11:39 am
by Koenkk
pin00b wrote:hi,
pretty slick.
This is probably a key mapping issue. You need to map the keys manually I guess :(
Posted: Mon Aug 13, 2012 11:50 am
by jared123
Looks good, I'll give it a test tonight :)
One thing I should point out - I was planning on using my old MCE remote to control XBMC on the pi (on whatever distribution I ended up with), but haven't even plugged it in. I've found the official XBMC remote app (for android and ios) works perfectly with all distributions, so it's definitely something I'd recommend for people who are having remote issues.
Posted: Mon Aug 13, 2012 11:56 am
by jared123
will.moindrot wrote:I just installed XBian and I think that it's great (1080p vids mkv >7gb over home network). If anybody is interested in seeing it in action and getting an overview I've uploaded a video here: http://www.youtube.com/watch?v=G2-eUrGbl0I
nice video :) might be an idea to rename your media files before posting a video online though ;)
Posted: Mon Aug 13, 2012 11:57 am
by rick19011
Does 0.6 have the cec hot fix already applied???
Posted: Mon Aug 13, 2012 3:44 pm
by HiggleBottom
Koenkk wrote:
HiggleBottom wrote:I guess I'll have to keep using Raspbmc. Sigh :cry:
It really has to something to do with your pi/sdcard or power adapter because ur the first to report this issue.
Thanks Koenkk! I didn't realise that my plug didn't have enough amps! Would not have thought of that!
Posted: Mon Aug 13, 2012 6:19 pm
by Koenkk
rick19011 wrote:Does 0.6 have the cec hot fix already applied???
Yes
Posted: Mon Aug 13, 2012 6:20 pm
by Koenkk
Is it working now?
Posted: Tue Aug 14, 2012 9:35 am
by pin00b
i don't think its the keymapping. the default keymapping from xbmc has always been fine.
i played around with it a little and tried one in the the keymaps folder just in case and it didn't make any difference.
i think it might be a combined kernel and lirc problem...wild guess though. i'll try and look into it further not sure how much help i'll be though.
Posted: Tue Aug 14, 2012 10:08 am
by Draven68
Hi, Koenkk
My Raspberry Pi finally arrived today. (yay)
Tried Xbian 0.6 and had no problems installing on running it. :D
I really appreciate your work on this Project. Thanks
Is there any way to change the Start-Up logo ?
Here's a quick design i did of an alternative logo which has a little more Xbmc flavour to it.
Posted: Tue Aug 14, 2012 10:27 am
by Koenkk
Draven68 wrote:Hi, Koenkk
Nice! New splash screen ;)
Posted: Tue Aug 14, 2012 10:40 am
by Draven68
Thanks, Koenkk :D
Posted: Tue Aug 14, 2012 10:43 am
by Koenkk
Draven68 wrote:Thanks, Koenkk :D
Just to let you know, I included this in xbian 0.6.1. Really like the design! :D
Posted: Tue Aug 14, 2012 11:17 am
by Draven68
Wow ! :o .... cool
i'm pleased you liked it.
Keep up the great work !
P.S. Here's a Version 2: slightly tilted and and a bit smaller.
Posted: Tue Aug 14, 2012 12:53 pm
by thedude123
I have a 32gb SD card. Is the image on the website ok to use for a larger SD card or is it made for smaller ones?
Posted: Tue Aug 14, 2012 2:02 pm
by j0nnymoe
thedude123 wrote:I have a 32gb SD card. Is the image on the website ok to use for a larger SD card or is it made for smaller ones?
You can use the image on larger cards, you will just need to resize the partition to fill the card.
Posted: Tue Aug 14, 2012 2:13 pm
by Penetratore
is there a list of formats which can be played on the RPI or its dependet on the software.
I`m asking because I had some problems with playing *.rmvb, *.vob, *.asf, *.wmv
Can the latest release run this formats.
BTW. Logo is super.
by Draven68
Oops messed up the last picture (a line above the X)
Fixed Now.
Posted: Tue Aug 14, 2012 2:25 pm
by Doktoren
About this, does anyone have a guide for doing this?
I found one on youtube, but the commands used in the video doesnt seem to do the same on Xbian (I just enter the terminal by pressing CTRL + C when the RasPi is booting.
Posted: Tue Aug 14, 2012 2:36 pm
by thedude123
Can I import my userdata from xbmc on openelec so I don't have to setup all of my stuff again?
Posted: Tue Aug 14, 2012 3:31 pm
by onetootreefor
thedude123 wrote:Can I import my userdata from xbmc on openelec so I don't have to setup all of my stuff again?
you can import your sources.xml and maybe your guisettings.xml but everything else its best to start off from scratch because they could be using different builds of xbmc which would cause it all not show up properly
Posted: Tue Aug 14, 2012 3:54 pm
by Koenkk
Draven68 wrote:Oops messed up the last picture (a line above the X)
Fixed Now.
Nice ;D like it :D
Posted: Tue Aug 14, 2012 4:15 pm
by kidg21
I'm having a similar issue. I had all of my input devices (KB, Mouse, MCE) plugged into a powered USB hub and was having nothing but problems navigating the menus. (key presses either didn't register or took several seconds)
I removed the hub from the Pi and plugged the MCE's IR directly into the a USB port on the Pi. Happily everything now runs smoothly. This doesn't seem to be a commonly reported issue so I thought that I'd mention it. I've tried other distros without issue.
Here is the hub that I'm using. http://www.monoprice.com/products/produ ... 1&format=2
BTW, nice work!
Killerbee wrote:Thanks Koen for this super fast image. :D 50 fps! @800/450 Mhz
One nasty thing: My logitech wireless keyboard/mouse K400 is not always detected by XBMC. The funny thing is it works in the terminal?!?
Any suggestions? I tried to plug in the receiver in a powered USB hub but the result was the same.
In previous XBian versions it was working better. Sometimes I had to reboot my pi to make my K400 work in XBMC.
Thanks KB
Posted: Tue Aug 14, 2012 6:47 pm
by Norfolk
masterluke wrote:It says "xbmc.bin used greatest stack depth: xxxx bytes left". This seems to disappear eventually, but can be quite annoying.
Also - Is anyone else seeing these messages in the black bar above the video? Or is anyone else using PAL SDTV and NOT seeing them?
I have the same message (actually two lines with the same message, but another amount of bytes) on top of my screen. I am also seeing two small black bars (top and bottom) but that's probably the video size.
Posted: Tue Aug 14, 2012 6:54 pm
by jerrylamos
On my linux notebook, I copy the SD image to a file using the ancient dangerous utility dd.
Then I compress it using gzip.
When my Raspian install gets borked, I do a gunzip to get the img file back, use gparted to wipe the SD to F32 format, then use dd to restore it.
I don't know how to do any of that with the Pi.
