will.moindrot
Re: XBian - Small, Fast, Lightweight XBMC solution
Mon Aug 13, 2012 10:38 am
I just installed XBian and I think that it's great (1080p vids mkv >7gb over home network). If anybody is interested in seeing it in action and getting an overview I've uploaded a video here: http://www.youtube.com/watch?v=G2-eUrGbl0I
pin00b
Mon Aug 13, 2012 11:06 am
hi,
just loaded the latest release 0.6
pretty slick.
i think this is the fastest so far out of openelec and raspbmc
the big problem i have is trying to use my mce remote doesn't work, i can move left to right and some other buttons. but the majority of the buttons don't work. e.g. select.
anybody else having this problem?
Koenkk
Mon Aug 13, 2012 11:39 am
pin00b wrote:hi,
pretty slick.
This is probably a key mapping issue. You need to map the keys manually I guess :(
jared123
Mon Aug 13, 2012 11:50 am
Looks good, I'll give it a test tonight :)
One thing I should point out - I was planning on using my old MCE remote to control XBMC on the pi (on whatever distribution I ended up with), but haven't even plugged it in. I've found the official XBMC remote app (for android and ios) works perfectly with all distributions, so it's definitely something I'd recommend for people who are having remote issues.
jared123
Mon Aug 13, 2012 11:56 am
will.moindrot wrote:I just installed XBian and I think that it's great (1080p vids mkv >7gb over home network). If anybody is interested in seeing it in action and getting an overview I've uploaded a video here: http://www.youtube.com/watch?v=G2-eUrGbl0I
nice video :) might be an idea to rename your media files before posting a video online though ;)
rick19011
Mon Aug 13, 2012 11:57 am
Does 0.6 have the cec hot fix already applied???
HiggleBottom
Mon Aug 13, 2012 3:44 pm
Koenkk wrote:
HiggleBottom wrote:I guess I'll have to keep using Raspbmc. Sigh :cry:
It really has to something to do with your pi/sdcard or power adapter because ur the first to report this issue.
Thanks Koenkk! I didn't realise that my plug didn't have enough amps! Would not have thought of that!
Koenkk
Mon Aug 13, 2012 6:19 pm
rick19011 wrote:Does 0.6 have the cec hot fix already applied???
Yes
Koenkk
Mon Aug 13, 2012 6:20 pm
Is it working now?
pin00b
Tue Aug 14, 2012 9:35 am
i don't think its the keymapping. the default keymapping from xbmc has always been fine.
i played around with it a little and tried one in the the keymaps folder just in case and it didn't make any difference.
i think it might be a combined kernel and lirc problem...wild guess though. i'll try and look into it further not sure how much help i'll be though.
Draven68
Tue Aug 14, 2012 10:08 am
Hi, Koenkk
My Raspberry Pi finally arrived today. (yay)
Tried Xbian 0.6 and had no problems installing on running it. :D
I really appreciate your work on this Project. Thanks
Is there any way to change the Start-Up logo ?
Here's a quick design i did of an alternative logo which has a little more Xbmc flavour to it.
Koenkk
Tue Aug 14, 2012 10:27 am
Draven68 wrote:Hi, Koenkk
Nice! New splash screen ;)
Draven68
Tue Aug 14, 2012 10:40 am
Thanks, Koenkk :D
Koenkk
Tue Aug 14, 2012 10:43 am
Draven68 wrote:Thanks, Koenkk :D
Just to let you know, I included this in xbian 0.6.1. Really like the design! :D
Draven68
Tue Aug 14, 2012 11:17 am
Wow ! :o .... cool
i'm pleased you liked it.
Keep up the great work !
P.S. Here's a Version 2: slightly tilted and and a bit smaller.
thedude123
Tue Aug 14, 2012 12:53 pm
I have a 32gb SD card. Is the image on the website ok to use for a larger SD card or is it made for smaller ones?
j0nnymoe
Tue Aug 14, 2012 2:02 pm
thedude123 wrote:I have a 32gb SD card. Is the image on the website ok to use for a larger SD card or is it made for smaller ones?
You can use the image on larger cards, you will just need to resize the partition to fill the card.
RPi[1]: Arrived 5/7/12 | RPi[2]: Arrived 10/7/12
PSN/XBL: m0euk
SGS3 i9305: CyanogenMod10.1 Nightlies
Penetratore
Tue Aug 14, 2012 2:13 pm
is there a list of formats which can be played on the RPI or its dependet on the software.
I`m asking because I had some problems with playing *.rmvb, *.vob, *.asf, *.wmv
Can the latest release run this formats.
BTW. Logo is super.
Draven68
Oops messed up the last picture (a line above the X)
Fixed Now.
Doktoren
Tue Aug 14, 2012 2:25 pm
About this, does anyone have a guide for doing this?
I found one on youtube, but the commands used in the video doesnt seem to do the same on Xbian (I just enter the terminal by pressing CTRL + C when the RasPi is booting.
thedude123
Tue Aug 14, 2012 2:36 pm
Can I import my userdata from xbmc on openelec so I don't have to setup all of my stuff again?
onetootreefor
Tue Aug 14, 2012 3:31 pm
thedude123 wrote:Can I import my userdata from xbmc on openelec so I don't have to setup all of my stuff again?
you can import your sources.xml and maybe your guisettings.xml but everything else its best to start off from scratch because they could be using different builds of xbmc which would cause it all not show up properly
Koenkk
Tue Aug 14, 2012 3:54 pm
Draven68 wrote:Oops messed up the last picture (a line above the X)
Fixed Now.
Nice ;D like it :D
kidg21
Tue Aug 14, 2012 4:15 pm
I'm having a similar issue. I had all of my input devices (KB, Mouse, MCE) plugged into a powered USB hub and was having nothing but problems navigating the menus. (key presses either didn't register or took several seconds)
I removed the hub from the Pi and plugged the MCE's IR directly into the a USB port on the Pi. Happily everything now runs smoothly. This doesn't seem to be a commonly reported issue so I thought that I'd mention it. I've tried other distros without issue.
Here is the hub that I'm using. http://www.monoprice.com/products/produ ... 1&format=2
BTW, nice work!
Killerbee wrote:Thanks Koen for this super fast image. :D 50 fps! @800/450 Mhz
One nasty thing: My logitech wireless keyboard/mouse K400 is not always detected by XBMC. The funny thing is it works in the terminal?!?
Any suggestions? I tried to plug in the receiver in a powered USB hub but the result was the same.
In previous XBian versions it was working better. Sometimes I had to reboot my pi to make my K400 work in XBMC.
Thanks KB
Norfolk
Tue Aug 14, 2012 6:47 pm
masterluke wrote:It says "xbmc.bin used greatest stack depth: xxxx bytes left". This seems to disappear eventually, but can be quite annoying.
Also - Is anyone else seeing these messages in the black bar above the video? Or is anyone else using PAL SDTV and NOT seeing them?
I have the same message (actually two lines with the same message, but another amount of bytes) on top of my screen. I am also seeing two small black bars (top and bottom) but that's probably the video size.
Return to “Media centres”
