fiskius
HD44780 display with OSMC
Fri Apr 24, 2015 11:52 pm
Had anyone got this HD44780 display working with OSMC? I've had it working no problems using RASPBMC but since the upgrade I can only get the top row of black blocks on the screen (Wiring is correct, but lcdproc is obviously not working).
I use these instructions for RASPMC: http://andypi.co.uk/?p=302
And followed similar steps below to get it working with OSMC, but only get the blocks. I'm using a Raspberry Pi version 1 B+. I know there is an update driver for the RPi 2, but I don't need that yet!
1. update software
sudo apt-get update
sudo apt-get install dpkg-dev gcc
sudo apt-get install lcdproc lcdproc-extra-drivers
select "Yes" perform auto config upgrade
2. Download AndyPi setting file (works with raspbmc) and replace the old one:
sudo wget -O /etc/LCDd.conf http://andypi.co.uk/downloads/LCDd.conf
sudo /etc/init.d/LCDd restart
3. Download & extract and replace hd44780.so ( for RPi 1) file in /usr/lib/lcdproc/
http://andypi.co.uk/downloads/raspdrivers.tar.gz
4. In the OSMC manin menu got to Settings >> Add-ons >> Get add-ons >> XBMC/Kodi add-on repository >> Services >> XBMC LCDproc >> Install
But no joy...
Any help appreciated!
Re: HD44780 display with OSMC
Sat Apr 25, 2015 1:50 am
Have you got a 10K trimpot between 5V0 & GND with the wiper connected to V0?
szalay
Sat Apr 25, 2015 9:42 pm
I have same problem like above "by fiskus"
If using old Raspbmc built (SD) then HD44780 display work well..
When installed new built "OSMC Kodi" the lcdproc doesn't seem work.
i have did step by step installations like above, and edited all files proper
like i did for old RaspBMC built, but i no luck the display is blank.
BTW: of course not the adjust contrast problem
sorry my bad English.
seem no one could help us ?
fiskius
Tue May 05, 2015 8:22 am
Yes, I have a contrast control pot, it is worked fine with RASPBMC and directly via python, it is not a hardware issue. I've tried both OSMC and OpenELEC, but can't get LCDproc to work.
I looked at this tutorial for OpenELEC(http://openelec.tv/forum/124-raspberry- ... lay#133784) and found: journalctl --no-pager -b -0
The output showed that LCDd failed to start - anyone any ideas why?
Rpi v1 Model B+
szalay
Tue May 05, 2015 3:17 pm
@fiskus
finally i got it work my LCD HD44780 on Rpi B rev2 using OSMC Kodi built
not really clean me how to get it, but working...
Tue May 05, 2015 4:50 pm
szalay wrote:@fiskus
What's your problem? Is it the wiring or the programming?
szalay
Wed May 06, 2015 12:38 pm
Basically I've solved the problem.
It's Install (programming) not really same as, like we did
for RaspBMC built.
fiskius
Sun May 10, 2015 11:31 pm
Any chance of posting some detailed instructions?
szalay
Mon May 11, 2015 1:23 pm
Yup, you could try I how get it work.
Fresh installed OSMC Kodi.
and make lcdproc folder in > /home/osmc/lcdproc/
and ftp'd the Andy's hd44780.so
(I have another patched .so file for rev2) works both.
1.
OMSC > Updating (Scan for updates now)
2.
sudo apt-get update
(select "Yes" perform auto config upgrade)
3.
4.
sudo apt-get install build-essential
5.Then Uninsall lcdproc:
sudo apt-get remove lcdproc
6. Reinstall lcdproc:
 Unpacking lcdproc-extra-drivers (0.5.7-2) ...
Setting up lcdproc (0.5.7-2) ...
Fixing lcdproc configuration...
it show "fixing lcdproc configuration" thats it !!
7.
sudo nano /etc/LCDd.conf
edit config file proper:
 ## This file was written by cme command.
## You can run 'cme edit <application>' to modify this file.
## Run 'cme list' to get the list of applications available on your system
## You may also modify the content of this file with your favorite editor.
[server]
DriverPath=/home/osmc/lcdproc/
Driver=hd44780
Bind=127.0.0.1
Port=13666
User=nobody
WaitTime=5
ServerScreen=no
NextScreenKey=Right
PrevScreenKey=Left
ReportToSyslog=yes
ToggleRotateKey=Enter
[menu]
DownKey=Down
EnterKey=Enter
MenuKey=Escape
UpKey=Up
## Hitachi HD44780 driver ##
[hd44780]
# Select what type of connection. See documentation for  types.
ConnectionType=rpi
D7=22
D6=27
D5=17
D4=23
RS=25
EN=24
Port=0x378
Speed=0
Size=16x2
8.
Enable/install LCDproc via OSMC
9.
done...
cheers..
wowko
Wed Jun 10, 2015 5:10 pm
szalay wrote:Yup, you could try I how get it work.
1.
2.
sudo apt-get update
3.
4.
7.
[server]
Driver=hd44780
Bind=127.0.0.1
Port=13666
User=nobody
WaitTime=5
ServerScreen=no
NextScreenKey=Right
PrevScreenKey=Left
ReportToSyslog=yes
[menu]
DownKey=Down
EnterKey=Enter
MenuKey=Escape
UpKey=Up
[hd44780]
ConnectionType=rpi
D7=22
D6=27
D5=17
D4=23
RS=25
EN=24
Port=0x378
Speed=0
Size=16x2
8.
9.
done...
cheers..
Hello, I followed all these steps but didn't create the directory for Andy's hd44780.so or copy the file to that folder until after completing the other steps. Now I just have the LCD with white blocks on the top row. What steps should I take to fix this? I tried uninstalling all and then running through the process again but now the Auto Config Upgrade screen doesn't come up. Any help is really appreciated. Thanks!
szalay
Thu Jun 11, 2015 1:52 pm
what Rpi model are you using same as like me?
because the Andy's.so LCDdriver for rpi1 rev2 model
and, I built the folder for hd44780.so myself via FTP
wowko
Sat Jun 13, 2015 12:29 am
I have a raspi 1 b+
szalay
Mon Jun 15, 2015 4:07 pm
Any news/lucky to get working LCD ?
kobiben
Sat Jul 18, 2015 7:46 pm
i followed everyone instructions but still could not find the cause for it to not working, but eventually i found out that the LCDd.conf file had invalid CRLF which i fixed by dos2unix it, and bamm, working like a charm.
sam nazarko
Sat Jul 18, 2015 8:36 pm
Can you post this tutorial at discourse.osmc.tv so we can add it to our how-to section?
Sam
szalay
Sat Jul 18, 2015 9:59 pm
kobiben wrote:i followed everyone instructions but still could not find the cause for it to not working, but eventually i found out that the LCDd.conf file had invalid CRLF which i fixed by dos2unix it, and bamm, working like a charm.
Nice, good to hear you finally got it works.
And yes, more info about "fixed by dos2unix it" ?
My next project Pi2, LCD through i2c serial interface on OSMC-kodi
fiskius
Tue Nov 10, 2015 6:50 pm
Well, a few months later... still issues.
I've been following szalay's instructions. I've tried OSMC and openelec, raspberry pi 1 B+ and pi 2, of all combinations using the correct hd44780 driver, tried 2 different LCDs, tripled checked wiring and I have the following, in all cases:
I get the top row of blocks only; when I enable the lcdproc in software, the backlight on the LCD starts to flicker randomly, but still with the top row of blocks.
So > basically lcdproc is not getting through to the LCD, since I don't even have 'welcome to LCDproc'.
I know the LCD's work, because I've tested them with a python app that writes to it directly. So the issue is with kodi variants and LCD proc. Is anyone else getting these issues? It's a shame as under RASPBMC everything was brilliant..
Cheers
Return to “Media centres”
