JACKD slave connect to master from pi
Posted: Sun Apr 05, 2015 3:53 pm
Network:
Master: Win8.1 x64 Desktop(D) with JACK Control(using portaudio)
Slaves: Win8.1 x64 Surface(S) with JACK Control(using net driver) / Raspberry Pi 2(P) with jackd
They all connected using wires with a 4 port switch on a router.
Scenarios:
Surface can listen the audio from Desktop, but Pi cannot listen from Desktop, always "waiting for master".
So I've tried some tests:
1. maybe the ttl matters?
ping between D ans S ttl is 128, P -> D or S is 128, D or S -> P is 64.
I don't think so, ttl is just a number in a packet, so jackd would like to check this?
2. the version is not match?
P has 1.9.9 version, while D and S have 1.9.10
Well, different minor version change doesn't matter what is transferred, I think.
3. Force master(D) to connect slave(P), jack_netsource.exe -H Pi -p 19000
P(jackd -R -d net) gives:
Does anyone have some suggestion to make Pi also play the audio like Surface?
Thank you for reading the long posts!
Scenarios:
D gives:(after the waiting for a master)
Initializing connection with ...
*************** Network parameters *************
Name :
Protocol revision : 2
MTU : 0
Master name :
Slave name :
Transport Sync : no
Send channels (audio - midi) : 0 - 0
Return channels (audio - midi) : 0 - 0
Sample rate : 0 frames per second
Period size : 0 frames per second
Network latency : 0 cycles
SampleEncoder : Fload
Slave mode : async
InitTime : multimedia timer resolution set to 1 milliseconds
MMCSS API not used...
too long packet received...Not Connected
