andoma
Movian (previously Showtime) now runs on RPi 2
Fri Mar 20, 2015 6:01 pm
Hi
Two things,
I've decided to rename Showtime to Movian (read more about why here: https://movian.tv/news/56).
Secondly, Movian now runs fine on Raspberry Pi 2
SD card image downloads can be found here: https://movian.tv/downloads/stos.
Joe Schmoe
Re: Movian (previously Showtime) now runs on RPi 2
Fri Mar 20, 2015 6:04 pm
What is it?
(When I first saw this, I assumed that the movie channel known as Showtime had renamed itself to something else. Imagine that...)
andoma
Fri Mar 20, 2015 6:28 pm
Yeah, That's exactly why I renamed it :-) To avoid confusion with the TV-channel.
It's a basically a media center. Full feature list can be found here https://movian.tv/projects/movian/wiki/Features
Joe Schmoe
Fri Mar 20, 2015 6:50 pm
OK - thanks.
piponito
Tue Apr 21, 2015 5:44 pm
Thank you andoma. It works like a charm on rpi2. And the best lan speeds, about 60mbps running a blu-ray 1:1 rip from my nas (upnp source). Better than openelec. :D
andoma
Tue Apr 21, 2015 7:23 pm
Cool!
The latest versions of Movian also support automatic mounting of media over USB. A feature that's asked by a lot of people it seems.
piponito
Wed Apr 22, 2015 4:16 pm
andoma wrote:Cool!
Thank you. What do you mean with "automatic mounting of media over USB"?
I'm using sd-2.1.2, but nothing happens when insert a pendrive with a bunch of films. What should I do?
andoma
Wed Apr 22, 2015 5:41 pm
I think the problem here is that there is no stable version of Movian itself released yet that supports this.
However, there are unstable versions, so if you go into "Settings" -> "General" and select "Bleeding edge" as upgrade track, and then check for new upgrades you will get a version that supports this.
When the next stable version of Movian is shipped the STOS image will be upgraded to ship with that.
It's a bit of a chicken and egg problem.
piponito
Wed Apr 22, 2015 6:01 pm
Ok andoma, thank you.
Return to “Media centres”
