Deebles87
Plex?
Mon Mar 02, 2015 6:11 am
Okay not sure If I should post this here or server.
So my plan for when I get my PI was to set it up to host my Plex movies on a external hard drive then use my xbox one and Roku stick in my daughters room to watch the media.
I figured I should check for a tutorial or something but all im finding is videos of people setting up their Pi's to actually watch the media. So I am asking can the pi Host my media for my other media devices? Just asking before I commit to buying plex premium.
(New to Pi havent even recieved it yet)
Dreadmouse
Re: Plex?
Fri Mar 06, 2015 9:03 am
Yes you absolutely can run a Plex server off this. That is exactly why I got mine. It depends on your level of comfort with linux but it can be done. First you will need to download a version of ubuntu that is specifically ported to work with the Pi 2 at https://wiki.ubuntu.com/ARM/RaspberryPi and follow the directions on getting it installed to the pi SD card.
once that is installed and you are able to boot into it then watch this video on how to set it up for plex media server. I suggest you keep a laptop nearby so you can follow the video as you are setting up the device. Video to watch is: https://www.youtube.com/watch?v=9jdbwlg ... 91&list=WL
Your external harddrive needs to have it's own power supply, the pi doesn't have enough amperage available to run itself and a hard drive. Something like this one will be perfect: http://www.amazon.com/Mediasonic-ProBox ... +enclosure
Good luck hope this helps you out
NedTheNerd
Re: Plex?
Tue Mar 10, 2015 9:43 am
Dreadmouse wrote:Yes you absolutely can run a Plex server off this. That is exactly why I got mine. It depends on your level of comfort with linux but it can be done. First you will need to download a version of ubuntu that is specifically ported to work with the Pi 2 at https://wiki.ubuntu.com/ARM/RaspberryPi and follow the directions on getting it installed to the pi SD card.
Obviously you have not tried your own 'solution', so why offer it.
What you are suggesting will never work as there is no Plex Media Server package for the Raspberry Pi available, there are packages for ARM processors, but these will not install the way you are suggesting and using the Ubuntu package is even a more ludicrous suggestion.
The RPi2 will run PMS, and will serve a limited number of Plex clients (i.e. Roku, Android, iOS, Samsung Smart devices, Rasplex, XBOne, XBox 360, Playstation, Plex HT, etc) but only by Direct Playing supported media, transcoding is out of the question.
I have PMS running on a RPi2, with an SSD external drive (contains the media), serving iPad's and iPhone's in the car and a second RPi2 running Rasplex when we're away from home.
Instructions can be found here https://forums.plex.tv/index.php/topic/ ... /?p=846534
Regards
Hardware: 1xRPi B 256Mb running Musicbox, 2 x RPi2's running Rasplex, RPi B+ running mail and web services, RPi2 running Plex Media Server
NedTheNerd
Re: Plex?
Tue Mar 10, 2015 9:50 am
Deebles87 wrote:Okay not sure If I should post this here or server.
See my response to Dreadmouse's post.
Regards
Return to “Media centres”
