Best solution for my scenario?
Posted: Fri Feb 27, 2015 12:08 am
by Harvs
Hi, as a student I have a modest set up, a small hdmi TV, amplifier with speakers 3.5mil jack. And a external hard drive with ~100 films. I'm looking for a solution that will preferably allow me to mount the hard drive and library.
But more importantly my housemates want;
AirPlay support (audio, but video would be a plus)
Google cast support (when the icon appears in the YouTube app etc)
Spotify connect support (hopeful, I know!)
General DLNA renderer functionality
I am currently using raspbmc, but I'm finding it very unstable and of the above list it only supports AirPlay audio
Does the rasplex do all/most of this
Ideally it would also support Netflix, iplayer, Amazon VOD as well
Thank you in advance
Re: Best solution for my scenario?
Posted: Fri Feb 27, 2015 8:06 am
by ghans
A company called VMLite used to give free beta keys for their Airplay mirroring software. Netflix will propably never work (even on the Pi2) thanks
to DRM.
Other than that , are you using OSMC or RaspBMC ? RaspBMC is supposed to be dead , all future work will be done on OSMC instead.
Are you sure your power-supply and USB cable are good - "Chargers" rated 1A (1000 mA) may under-deliver when loaded.
ghans
Posted: Sat Feb 28, 2015 2:32 pm
by Harvs
I'm currently using Raspbmc becasue I struggled with the UI with OSMC and got constant hangs, I have tried a stock Galaxy s4 charger, an iPad charger and a multi charger rated up to 5A all with the same stability issues. I'm waiting to update to OSMC when it comes out of alpha
Posted: Sat Feb 28, 2015 3:24 pm
by abishur
You might want to give openElec a try, it at a more stable release than the alpha OSMC is at presently.
