Douglas6
Re: Another How to turn your Pi in a Bluetooth Speaker Tutorial
Sun Jul 04, 2021 8:44 pm
This tutorial does some arguable things to your Pi. More importantly for you, it does nothing to address telephones on the Pi.
You'll want to
sudo apt install ofono
Ofono handles the telephony side of things. I've just started playing with it myself. It does the things you're asking for.
Don't forget to unpair and re-pair your Pi and phone after installing Ofono.
yomguy
Fri Jul 16, 2021 7:10 am
So great, thanks!
FYI I just had to do a
rfkill unblock all
before
power on
PrettyFlyForAFatGuy
Wed Jul 28, 2021 6:16 pm
This works on the Tinkerboard S too up to (and including) section 6
drpepper45
Wed Aug 11, 2021 10:01 pm
Great tutorial, thank you so much!
I am running into an issue though: if I do "Forget This Device" from my phone, the bluetooth unpairs but the rapsberry pi stores the MAC address of that device, so that the following time I want to pair it, it gives me an error "Pairing Unsuccessful". The only way around it is to manually remove the MAC address from that device from the raspberry pi. Is there a way to have the pi automatically remove any known devices when they disconnect? Or any other way around?
I know I should only do "disconnect" instead of "forget this device" but I am trying to make this as robust as possible.
PS: I would add in this tutorial how to edit the bluetooth name of the device (see here: https://www.hackster.io/highvoltages/ho ... ame-aa5966)
Return to “Media centres”
