peppy.player
Re: Peppy player
Fri Feb 12, 2021 5:21 pm
Do you use Pi 3?
Have you tried to refresh the screen after selecting the network?
I'll try to rotate 5" screen and let you know the result.
Best regards
peppy.player
Re: Peppy player
Fri Feb 12, 2021 6:51 pm
I was able to make UI show up after rotation but it doesn't work when you click on icons in the Home screen. The code needs to be changed to make it working. So unfortunately the answer is - the vertical layout is not supported right now.
Best regards
loic.avenel
Re: Peppy player
Sun Feb 14, 2021 6:48 pm
Yes, I am using PI3... I made it work by selecting US as a local.. I will do more testing.. Thanks
peppy.player
Re: Peppy player
Wed Mar 03, 2021 5:17 pm
Here is the new project based on the Peppy Player. The project name is 'Dietrich' after 'DIgital TRansport. This is the ancient German name which means - 'Ruler of the people' ;)
The device consists of:
- Power supply +12V 12.5A for external hard drives and for the power switch LED
- Power Supply +5V 10A for the Raspberry Pi 4, USB Hub and display
- Raspberry Pi 4. One USB2 connected to the touchscreen. Another USB2 connected to the back panel. One USB3 connected to the USB Hub. Another USB3 connected to the back panel. LAN connected to the back panel. One HDMI connected to the display. Another HDMI connected to the back panel.
- USB3 Hub 10 port
- Waveshare 7.9" touchscreen
- 8 Relay Module to switch on/off 12V for external hard drives
- MCP23017 module to control relays through I2C
- ULN2803 sink driver transistor array
The device can work as:
- Audio player with USB output using hard drives connected to it.
- Audio player with USB output using NAS mounted to it.
- Video player with HDMI output (currently not supported in Peppy Player)
- Serve as a NAS for external hard drives connected to it.
- Streamer.
The pictures were taken with Peppy Player running on device (VU Meter screensaver).
The support for switching on/off hard drives from UI will be added to the Peppy Player software in one of the next releases.
ocean1598
Re: Peppy player
Tue Mar 09, 2021 11:42 pm
:D :)
My goodness, this looks great!!!
peppy.player
Re: Peppy player
Tue Apr 20, 2021 1:26 am
Here is the new entry in the Peppy Player Gallery - RetroPeppy by Christian (Germany):
https://github.com/project-owner/PeppyP ... an-germany
peppy.player
Re: Peppy player
Wed Apr 28, 2021 5:19 pm
There is one more entry in the Gallery - Bathroom Player by Flup (Germany):
https://github.com/project-owner/PeppyP ... up-germany
It has a 3D printed enclosure.
peppy.player
Re: Peppy player
Mon May 03, 2021 2:47 am
New version (Hiroshige Edition) of the Peppy Player was released today.
The disk images with new release are available here:
https://github.com/project-owner/PeppyP ... isk-Images
The complete list of changes is available in the Release Notes:
https://github.com/project-owner/PeppyP ... ease-Notes
Here are the main features of the release:
- Implemented USB disk auto-mount functionality which also includes a Disk Manager Web UI.
- Created UI to set Timezone, set Default values and observe the log file.
- Screensaver delay moved to the Web UI
- Redesigned Radio player and station browser screens.
- Modified the keyboard navigation. All screen elements are accessible now using just arrow keys.
Return to “Media centres”
