MitraMai
Thought I should share the config-files for the Argon remote for Kodi...
Thu Apr 08, 2021 7:21 pm
Hello!
I've managed to get the Argon remote working with Kodi, so I thought I should share the config-files. Argon40 do provide a setup of the remote for LibreElec, but not for Raspbian so it took me a while to figure it all out.
Running the script "argonone-ir" does output the lirc-file, but it is missing the back-key. So I also include my argon.lirc.conf that goes into
/etc/lirc/lirc.d.conf
# Based on NEC templates at http://lirc.sourceforge.net/remotes/nec/
# Configured codes based on data gathered
begin remote
  name  argon
  bits           32
  flags SPACE_ENC
  eps            20
  aeps          200
  header       8800  4400
  one           550  1650
  zero          550   550
  ptrail        550
  repeat       8800  2200
  gap          38500
  toggle_bit      0
  frequency    38000
      begin codes
          KEY_UP                0x00ff53ac
          KEY_DOWN                0x00ff4bb4
          KEY_LEFT                0x00ff9966
          KEY_RIGHT                0x00ff837c
          KEY_VOLUMEUP                0x00ff01fe
          KEY_VOLUMEDOWN                0x00ff817e
          KEY_OK                0x00ff738c
          KEY_HOME                0x00ffd32c
          KEY_MENUBACK                0x00ffb946
          KEY_BACK                 0x00ff09f6
      end codes
end remote
and then the Lircmap.xml (note the capital L) in
~/.kodi/userdata
<lircmap>
  <remote device="argon">
         <left>KEY_LEFT</left>
        <right>KEY_RIGHT</right>
        <up>KEY_UP</up>
        <down>KEY_DOWN</down>
        <back>KEY_BACK</back>
        <select>KEY_OK</select>
        <menu>KEY_MENUBACK</menu>
        <start>KEY_HOME</start>
        <volumeplus>KEY_VOLUMEUP</volumeplus>
        <volumeminus>KEY_VOLUMEDOWN</volumeminus>
  </remote>
</lircmap>
and then the argon.xml that goes into
~/.kodi/userdata/keymaps
<keymap>
  <global>
    <remote>
      <play>Select</play>
      <up>Up</up>
      <down>Down</down>
      <left>Left</left>
      <right>Right</right>
      <menu>Menu</menu>
        <home>Home</home>
        <back>Back</back>
    </remote>
  </global>
  <fullscreenvideo>
    <remote>
      <play>PlayPause</play>
      <up>VolumeUp</up>
      <down>VolumeDown</down>
      <right>StepForward</right>
      <left>StepBackward</left>
        <menu>OSD</menu>
    </remote>
  </fullscreenvideo>
</keymap>
Then just restart kodi and lirc (don't know if restarting the lirc-daemon is necessary):
sudo systemctl restart kodi.service && sudo systemctl restart lircd.service
and now it should work!
Return to “Media centres”
