ejarosek
RPi4: 4k60 video on one hdmi, audio pass through on other?
Sat Jun 29, 2019 1:42 pm
So, I ran out and grabbed the new Raspberry PI 4 when they came into stock at Microcenter to enable 4k HEVC content on my 4k TV. In the process of setting it up I ran into an issue. Apparently my receiver, even though it will output 4k, will not allow a 4k input. If I plug the RPi directly into the TV the 4k works great but the ARC only support PCM PII so I lose my surround.
So, the question: would it be possible to have the PI push the video through one HDMI port (maintaining 4kp60) to the TV directly and the audio through the other port directly to the receiver?
Re: RPi4: 4k60 video on one hdmi, audio pass through on other?
Sun Jun 30, 2019 8:55 am
This is on my list of things to look at. It's a useful use case. Cannot give any schedule though.
cocodude
Thu Sep 26, 2019 9:18 pm
I've been trying to do exactly this.
It does seem to work in general; I can quite easily get 4kp60 video out on HDMI 0 and some sound out on HDMI 1 (if I right click on the speaker icon on the desktop and change the output to HDMI 1). However, whatever I try, I think I can only send two channel PCM to this. I can't passthrough any other sources like Dolby Digital using Kodi, VLC or anything really.
Passthrough appears to work just fine when both video and sound are going through HDMI 0.
armyofme
Thu Nov 21, 2019 9:05 pm
Does anyone know if there has been any progress on this issue? Would be great to have passthrough on hdmi 1.
vazma
Mon Dec 16, 2019 2:05 pm
I am very interested also in order to forward video to an output (projector) and the sound to another rpi with hifiberry and from there to my sound system. Lets see if there is any similar case..
Cheers,
Vasilis
vazma
Mon Dec 16, 2019 6:05 pm
Cheers,
Vasilis
Mon Dec 16, 2019 8:21 pm
You can set the audio out to which ever HDMI port you want, even if video goes to the other one. Just select the required port from the audio option on the task bar.
armyofme
Mon Dec 23, 2019 7:19 pm
But it doesn't work for pass through :( Passthrough only works when video and audio are both on hdmi0.
Mon Dec 23, 2019 9:43 pm
Ah, that sounds likely. Not quite sure how passthrough works.
sking
Sun Dec 29, 2019 4:11 am
i have the same result,HDMI 1can hear,but only two channel
croft
Fri Feb 07, 2020 4:19 pm
hi
can vlc be set to send sound through av sound output
i have not found a anser yet
thanks
croft
dorian-ny
Fri Apr 17, 2020 7:53 pm
As long as your audio receiver supports surround LPCM over HDMI there is no need for passthrough. The audio signal will be decoded by the Raspberry and sent over raw LPCM multichannel.
armyofme
Sat Jul 25, 2020 10:53 am
This has now been achieved in the latest nightly of Libreelec - I now have passthrough on HDMI2! Hoping it won't be long before it's also working on the Raspberry OS too :)
philbio
Sun Sep 20, 2020 12:27 am
Old thread I know, just confirming you have video output on HDMI 1 and passthrough on HDMI 2 to an AVR?
armyofme
Mon Sep 21, 2020 5:20 pm
Yes this is possible with Libreelec nightly. I'm just hoping it will come to Kodi on the Raspberry Pi OS soon too.
philbio
Mon Sep 21, 2020 9:30 pm
How did you achieve this, I can't get it to work, I have a Denon AVR which is detected by libreelec nightly on HDMI2 (works fine with video/audio combined on the same hdmi port), but no audio passthrough output on HDMI2 when Video on HDMI1? Thanks for any info.
armyofme
Sun Sep 27, 2020 12:21 pm
I used a nightly version from beginning of August. I also have the Denon amp and passthrough was working with Liberelec. I stopped using it as I missed the functunality of the Raspberry OS. Really hoping the Libreelec audio improvement updates come to Kodi on Raspberry OS.
I think I still have the libreelec sd card so I'll have a look at which nightly it was that worked (- although I would have thought that all nightlys since then would include this).
philbio
Sun Sep 27, 2020 9:02 pm
Thanks for the update, see what you can dig up, on the face of it looks like something broke since your nightly that works.
philbio
Fri Oct 09, 2020 11:54 pm
It appears that 16th August 2020 nightly was successful (https://forum.libreelec.tv/thread/22302 ... post143378).
I'm unable to locate this build for testing as its no longer available.
Return to “Media centres”
