Balast
Rasbian RPi 4 kodi unable to create gui dtoverlay=vc4-fkms-v3d
Wed Aug 12, 2020 5:56 am
(Resolved)
Hello! Comrades, help. There is an RPi 4 connected to a TV (Samsung UE46ES6550) by HDMI cable, Rasbian is installed on the RPI.
Installed Kodi, according to the forums and instructions, you need to add the dtoverlay = vc4-fkms-v3d parameter to config.txt.
When adding a parameter and loading Rasbian, I get a black TV screen (No signal). Without this parameter, the system boots, but kodi refuses to start. (unable to create gui )
Tell me, can anyone come across this issue.
config.txt:
disable_overscan=1
dtparam=audio=on
max_framebuffers=2
hdmi_force_hotplug=1
hdmi_ignore_edid=0xa5000080
gpu_mem=256
kodi.log:
2020-08-12 02:01:09.835 T:2973002848 NOTICE: -----------------------------------------------------------------------
2020-08-12 02:01:09.835 T:2973002848 NOTICE: Starting Kodi (18.7 Git:20200528-2c5354e70a). Platform: Linux ARM 32-bit
2020-08-12 02:01:09.835 T:2973002848 NOTICE: Using Release Kodi x32 build
2020-08-12 02:01:09.835 T:2973002848 NOTICE: Kodi compiled 2020-06-12 by GCC 8.3.0 for Linux ARM 32-bit version 4.18.20 (266772)
2020-08-12 02:01:09.835 T:2973002848 NOTICE: Running on Raspbian GNU/Linux 10 (buster), kernel: Linux ARM 32-bit version 5.4.51-v7l+
2020-08-12 02:01:09.842 T:2973002848 NOTICE: FFmpeg version/source: 4.0.4-Kodi
2020-08-12 02:01:09.842 T:2973002848 NOTICE: Host CPU: ARMv7 Processor rev 3 (v7l), 4 cores available
2020-08-12 02:01:09.842 T:2973002848 NOTICE: ARM Features: Neon enabled
2020-08-12 02:01:09.842 T:2973002848 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2020-08-12 02:01:09.842 T:2973002848 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2020-08-12 02:01:09.842 T:2973002848 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2020-08-12 02:01:09.842 T:2973002848 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2020-08-12 02:01:09.843 T:2973002848 NOTICE: special://envhome/ is mapped to: /home/pi
2020-08-12 02:01:09.843 T:2973002848 NOTICE: special://home/ is mapped to: /home/pi/.kodi
2020-08-12 02:01:09.843 T:2973002848 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2020-08-12 02:01:09.843 T:2973002848 NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2020-08-12 02:01:09.843 T:2973002848 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v8
2020-08-12 02:01:09.843 T:2973002848 NOTICE: Local hostname: raspberrypi
2020-08-12 02:01:09.843 T:2973002848 NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2020-08-12 02:01:09.846 T:2973002848 NOTICE: -----------------------------------------------------------------------
2020-08-12 02:01:09.854 T:2973002848 INFO: loading settings
2020-08-12 02:01:09.859 T:2973002848 NOTICE: special://profile/ is mapped to: special://masterprofile/
2020-08-12 02:01:09.897 T:2973002848 DEBUG: CSkinSettings: no <skinsettings> tag found
2020-08-12 02:01:09.901 T:2973002848 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2020-08-12 02:01:09.901 T:2973002848 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
2020-08-12 02:01:09.901 T:2973002848 WARNING: CSettingsManager: missing version attribute
2020-08-12 02:01:09.903 T:2973002848 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2020-08-12 02:01:09.903 T:2973002848 NOTICE: Default Video Player: VideoPlayer
2020-08-12 02:01:09.903 T:2973002848 NOTICE: Default Audio Player: paplayer
2020-08-12 02:01:09.903 T:2973002848 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2020-08-12 02:01:09.903 T:2973002848 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2020-08-12 02:01:10.067 T:2973002848 NOTICE: PulseAudio: Server not running
2020-08-12 02:01:10.119 T:2973002848 NOTICE: Running database version Addons27
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: game.controller.default v1.0.8 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: game.controller.snes v1.0.8 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2020-08-12 02:01:10.210 T:2973002848 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: kodi.resource v1.0.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.local v1.0.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: repository.xbmc.org v3.1.6 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.33 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.59 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: script.module.pil v1.1.7 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: skin.estouchy v2.0.28 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: skin.estuary v2.0.27 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: xbmc.addon v18.7 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: xbmc.core v0.1.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: xbmc.gui v5.14.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: xbmc.json v10.3.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: xbmc.python v2.26.0 installed
2020-08-12 02:01:10.211 T:2973002848 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2020-08-12 02:01:10.234 T:2973002848 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2020-08-12 02:01:10.351 T:2942300368 NOTICE: Found 2 Lists of Devices
2020-08-12 02:01:10.351 T:2942300368 NOTICE: Enumerated ALSA devices:
2020-08-12 02:01:10.351 T:2942300368 NOTICE: Device 1
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_deviceName : @
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_displayName : Default (bcm2835 HDMI 1 bcm2835 HDMI 1)
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_displayNameExtra:
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_channels : FL, FR
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_streamTypes : No passthrough capabilities
2020-08-12 02:01:10.352 T:2942300368 NOTICE: Device 2
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_deviceName : sysdefault:CARD=b1
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_displayName : bcm2835 HDMI 1
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_displayNameExtra: bcm2835 HDMI 1
2020-08-12 02:01:10.352 T:2942300368 NOTICE: Device 3
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_deviceName : sysdefault:CARD=Headphones
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_displayName : bcm2835 Headphones
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_displayNameExtra: bcm2835 Headphones
2020-08-12 02:01:10.352 T:2942300368 NOTICE: Enumerated PI devices:
2020-08-12 02:01:10.352 T:2942300368 NOTICE: Device 1
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_deviceName : HDMI
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_displayName : HDMI
2020-08-12 02:01:10.352 T:2942300368 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_channels : FL, FR
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2020-08-12 02:01:10.353 T:2942300368 NOTICE: Device 2
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_deviceName : Analogue
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_displayName : Analogue
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_displayNameExtra:
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_sampleRates : 48000
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_streamTypes : No passthrough capabilities
2020-08-12 02:01:10.353 T:2942300368 NOTICE: Device 3
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_deviceName : Both
2020-08-12 02:01:10.353 T:2942300368 NOTICE: m_displayName : HDMI and Analogue
2020-08-12 02:01:10.445 T:2973002848 NOTICE: Raspberry PI firmware version: Jul 17 2020 10:59:17
Copyright (c) 2012 Broadcom
version 21a15cb094f41c7506ad65d2cb9b29c550693057 (clean) (release) (start)
2020-08-12 02:01:10.445 T:2973002848 NOTICE: ARM mem: 768MB GPU mem: 256MB MPG2:0 WVC1:0
2020-08-12 02:01:10.445 T:2973002848 NOTICE: Config:
arm_freq=1500
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=500
core_freq_min=200
disable_commandline_tags=2
disable_l2cache=1
disable_overscan=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
enable_gic=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=250
hdmi_channel_map=8
init_uart_clock=0x2dc6c00
lcd_framerate=60
max_framebuffers=2
over_voltage_avs=-23750
pause_burst_frames=1
program_serial_random=1
total_mem=4096
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_force_hotplug:0=1
hdmi_ignore_edid:0=0xa5000080
hdmi_pixel_freq_limit:0=0x11e1a300
hdmi_pixel_freq_limit:1=0x11e1a300
device_tree=-
overlay_prefix=overlays/
hdmi_cvt:0=
hdmi_cvt:1=
hdmi_edid_filename:0=
hdmi_edid_filename:1=
hdmi_timings:0=
hdmi_timings:1=
2020-08-12 02:01:11.358 T:2973002848 ERROR: CWinSystemGbm::InitWindowSystem - failed to initialize Atomic DRM
2020-08-12 02:01:12.278 T:2973002848 ERROR: CWinSystemGbm::InitWindowSystem - failed to initialize Legacy DRM
2020-08-12 02:01:13.200 T:2973002848 ERROR: CWinSystemGbm::InitWindowSystem - failed to initialize off screen DRM
2020-08-12 02:01:13.200 T:2973002848 FATAL: CApplication::Create: Unable to init windowing system
2020-08-12 02:01:13.200 T:2973002848 NOTICE: Stopping player
2020-08-12 02:01:13.200 T:2973002848 NOTICE: Storing total System Uptime
2020-08-12 02:01:13.201 T:2973002848 NOTICE: Saving settings
2020-08-12 02:01:13.206 T:2973002848 NOTICE: Saving skin settings
2020-08-12 02:01:13.206 T:2973002848 NOTICE: Stopping all
2020-08-12 02:01:13.211 T:2973002848 NOTICE: stop dvd detect media
2020-08-12 02:01:13.359 T:2973002848 NOTICE: Application stopped
2020-08-12 02:01:13.560 T:2973002848 NOTICE: unload skin
2020-08-12 02:01:13.560 T:2973002848 WARNING: CGBMUtils::DestroySurface - surface already destroyed
2020-08-12 02:01:13.560 T:2973002848 NOTICE: unload sections
2020-08-12 02:01:13.564 T:2973002848 WARNING: CGBMUtils::DestroyDevice - device already destroyed
LTolledo
Re: Rasbian RPi 4 kodi unable to create gui dtoverlay=vc4-fkms-v3d
Wed Aug 12, 2020 1:47 pm
on my RPi4B-4G mine has been set by default
am still in previous kernel (4.19 something)
and enjoying watching video on my RPi4-8G's Kodi install.... (cloned from RPi4B-4G's microSD card)
Some people be like:
armyofme
Thu Aug 13, 2020 12:02 pm
Hi Balast,
Have you tried using the other HDMI port? I believe that the second port is not fully fuctional yet as it's still being worked on.
Balast
Thu Aug 13, 2020 2:44 pm
LTolledo, maybe you colud share your backup file with configuration that worked in your case, if you still have one saved? That would be a big help.
Balast
Thu Aug 13, 2020 2:47 pm
armyofme, yes I tried another port of PBS and I get the same result
Rascas
Thu Aug 13, 2020 3:41 pm
Kodi works fine on the RPi 4 with the default settings. You don't need to add anything to config.txt except for increasing the GPU memory, the recommend for the Pi 4 is gpu_mem=320. You have more information here: viewtopic.php?f=66&t=251645
One important thing is that if you are launching Kodi from the Desktop Environment, the user needs to belong to the sudo users and not have a password defined. I am not going into detail about that, but again, you can find more information on the link above.
LTolledo
Thu Aug 13, 2020 10:17 pm
my suggestion:
on another microSD card flash a fresh RPiOS32
boot from new microSD, finish initial install.
update and upgrade
then increase GPU memory (as recommended by Rascas)
then install Kodi
then try it.
if it works fine then
you may opt to copy the config to the other setup, or
install your other apps and copy your data to this new microSD so that its almost the same as your old one.
if it does not work then
you may try downgrading the kernel from 5.4 to 4.19
Balast
Fri Aug 14, 2020 11:33 am
Raspbian OS not load with default settings, i get balck screeen on TV (no signal).
If I remove the following parameter from config.txt
and then add this one -
the system starts working and I can see the rainbow and desktop.
Balast
Fri Aug 14, 2020 1:55 pm
my suggestion:
update and upgrade
then install Kodi
then try it.
Do you have instructions, how i can downgrade the kernel from 5.4 to 4.19?
Balast
Fri Aug 14, 2020 3:13 pm
my suggestion:
update and upgrade
then install Kodi
then try it.
I downgraded it to 4.19 - still won't launch
Balast
Fri Aug 21, 2020 3:19 pm
Resolved!
At first I decided that the problem was in my TV and tried it on another TV and monitor, got the same result.
I bought a new HDMI cable and it worked, everything was decided by replacing HDMI.
This one was originally
https://smartbuy-rus.ru/smartbuy-cable- ... 1-8-m-gol/
Then I bought it and made money on this
https://defender.ru/catalog/audio-video ... ctive_tab=
Thanks to everyone who helped me.
Return to “Media centres”
