WhyNine
TVheadend as SAT>IP server not working
Fri Feb 07, 2020 6:10 pm
I am trying to get tvheadend to work as a SAT>IP server with the TV Hat on an RPi3.
After installing tvheadend, I can find the local Freeview channels using the TV Hat, so everything is basically working. I then set the SAT>IP source number for the network to 1, the number of exported DVB-T tuners to 1 and the RTSP port to 554 (also tried 9983 with same result). The log reports:
2020-02-07 17:19:28.664 satips: RTSP port 554 specified but no root perms, using 9983
2020-02-07 17:19:28.664 satips: SAT>IP Server reinitialized
2020-02-07 17:19:28.664 satips:   HTTP 192.168.1.142:9981, RTSP 192.168.1.142:9983
2020-02-07 17:19:28.664 satips:   descramble 1, muxcnf 0
2020-02-07 17:19:28.664 satips:   tuner[fe=1]: DVB-T #1
Using tvheadend on another RPi, I can't disover the first RPi3. I have also tried VLC and DVBViewer, neither of which can discover it either.
What am I doing wrong?
my-pi-x
Re: TVheadend as SAT>IP server not working
Wed Aug 05, 2020 5:12 pm
Still not working as "SAT>IP Server" ...
Device:		cat /sys/firmware/devicetree/base/model
				Raspberry Pi 3 Model B Plus Rev 1.3
OS: 		cat /etc/*release
				PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
Kernel:		uname -a
				Linux ... 5.4.51-v7+ #1327 SMP Thu Jul 23 10:58:46 BST 2020 armv7l GNU/Linux
TVheadend:	tvheadend --version
				tvheadend: version 4.2.8-34~g24a2f59e9
First SAT>IP Server: Panasonic-TV (Second SAT-Tuner/Astra 19° and Hotbird 13° East via Diseqc)
First SAT>IP Client: TVHeadend
Working fine. All Programms and all Epg-Data ... All these I can grep with Kodi with the HTS-Plugin on another PI with Kodi.
And here is my Problem:
Second SAT>IP Server: TVHeadend
Not working - TVHeadend is not showing an UUID.
Also on this Pi with Rasbpian I deleted/purged sudo.
TVHeadend was configured with root.
TVHeadend is running in a local network only (no internet)
Listen Services: netstat -tulpen
	tcp        0      0 0.0.0.0:9981		0	... 	432/tvheadend
	tcp        0      0 0.0.0.0:9982		0	... 	432/tvheadend
	udp        0      0 239.255.255.250:1900	109	... 	432/tvheadend
	udp        0      0 0.0.0.0:51018		109	... 	432/tvheadend
User:		hts:x:109:114::/home/hts:/bin/bash
group:		hts:x:114:
Is this maybe my problem?
My intention was/is to offer other "SAT>IP"-Clients, for exp. via HLS, VOD or nearly-VOD.
Thanks for help!
Btw.:
https://tvheadend.org/boards/5/topics/40569
Ogoshi
Fri Aug 28, 2020 2:34 pm
Have you restarted tvheadend service after enabling it as a sat>ip server? That's all I needed to do
Return to “Media centres”
