BTL00
Line6 UX2 / Raspberry Pi 3 / Spotify - help needed
Sat Jul 14, 2018 3:32 pm
Hey Gals and Guys!
I'm trying to make myself a Spotify streaming device using Raspotify (https://github.com/dtcooper/raspotify). Unfortunately, I don't have any good USB DAC / soundcard and I wanted to use my UX2 guitar interface. It doesn't have any support for Raspberry Pi, but Ubuntu has some packages that can make the device running: https://launchpad.net/ubuntu/+source/line6-usb
Is there any way to install them?
Also, I found some code repo that unfortunately I cannot compile (errors during 'sudo make install')
http://sourceforge.net/p/line6linux/
jack_on_fire
Re: Line6 UX2 / Raspberry Pi 3 / Spotify - help needed
Wed Jan 02, 2019 3:30 pm
Driver modules for the UX2 and a number of other Line 6 devices are actually included in the current Raspberry Pi kernel sources, but not in the default Raspbian kernel builds. You can build and install the modules from the kernel sources, or build your own kernel with a modified configuration.
For me, enabling playback from my UX1 on the Raspberry Pi 3 B+, was this easy:
- Follow the guide on https://www.raspberrypi.org/documentati ... uilding.md on how to build your own kernel, with one extra step:
- after creating the default build configuration and before building and installing the kernel, modules, and Device Tree blobs, modify the .config file to set the configuration parameters for the necessary modules to "m":
$ sed -ri "/CONFIG_SND_USB_TONEPORT/ { s/# (\w+).*/\1=m/; i CONFIG_SND_USB_LINE6=m
}" .config
The CONFIG_SND_USB_TONEPORT module should work for the TonePort GX, UX1 and UX2, for other Line 6 hardware you may want to do analogous changes to the lines with CONFIG_SND_USB_POD and CONFIG_SND_USB_PODHD.
BTL00
Mon Oct 28, 2019 8:35 pm
Thanks guys! I'll check that this weekend :D
remixmabix
Mon Dec 30, 2019 3:23 am
Hello people, maybe you can help me, everything is working with my raspberry pi 3 model b+ and shairport.
It seems that when Pod UX1 and Ethernet cable are plugged in, raspberry pi won't boot.
After some IOCTL DELAY I turned on dwc_otg.speed=1 and smsc95xx.turbo_mode=N in cmdline.txt according to https://wiki.linuxaudio.org/wiki/raspberrypi
Do you need to extra power the Pod UX1 or the PI ?
Have you noticed some laggy behaviour ?
Thanks.
sk8wine
Thu Jun 25, 2020 10:12 pm
Edit: I've successfully followed the instructions, see next comment :oops: :D
sk8wine
Fri Jun 26, 2020 11:16 am
}" .config
:D :D :D :D That worked for my UX1 studio too (Newer version from toneport), on Raspberry Pi 4 – I missed part two, most important bit...:
}" .config
Can confirm after going back to pre build, putting this code in, and rebuilding it has now successfully worked! Line 6 UX1 studio is a go
THANK YOU @jack_on_fire
vbarna
Tue Aug 11, 2020 7:20 pm
Hello guys,
when I'm trying to modify the config file, I get this: "sed: couldn't edit (.config): not a regular file". I'm using the Blokas Patchbox OS. Is my problem with the os, or am I overlooking something?
Return to “Media centres”
