DakotaFleck
Car Media Center HELP
Fri Apr 13, 2018 1:25 pm
Hello. I am still new to Raspberry Pi, but I know the general "how-to" with it. Recently, I came across a Raspberry Pi 1 Model B 512 MB and I impulsively bought it. Now I am wanting to create a car media center and I am unsure as to which components to use. I believe that the easiest way would be to go through the OBD II port(which is required in every automobile after 1996) so that i wouldn't have to do a lot of rewiring. As to features, i'm not a big fan of a touchscreen but I would like a tablet-like display. I would much rather control it with a remote or buttons of some kind. I would also like to be able to still use the radio. My final main feature, is that i would like to be able to view the diagnostics of my vehicle, which is another reason I wish to go through the OBD II port. If anyone can offer any help as to the components and software I should use, I would gladly appreciate it.
Re: Car Media Center HELP
Sat Apr 14, 2018 5:02 am
OBDII is only for diagnostics and nothing to do with ICE.
Google will find many projects and no one size fits all. Break it down to manageable parts and see how far you get.
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
DakotaFleck
Sat Apr 14, 2018 8:42 pm
I've seen a few projects where, instead of wiring everything into like their fuse box, they ran it off of the OBD II port and i thought it would be the easiest way
After doing some research, I found components that I would like to use. I am curious as to if there will be any compatibility issues for each of them. Here's what I plan to use:
- Raspberry Pi Model B 512 MB
-SanDisk 16GB Class 10 SDHC UHS-I Up to 80MB/s Memory Card SDSDUNC-016G-GN6IN(https://www.amazon.com/gp/product/B0143 ... 0DER&psc=1)
- LeeKooLuu Backup Camera and Monitor Kit for Car/Vehicle/Truck Waterproof Night Vision License Plate rear view Camera wire Single power source Rear view/Full-time view Optional 4.3 Display Grid Lines(https://www.amazon.com/gp/product/B06XK ... ZYZQ&psc=1)
- 3A Car Supply/Switch(https://mausberry-circuits.myshopify.co ... y-switch-1)
- Edimax EW-7811Un 150Mbps 11n Wi-Fi USB Adapter, Nano Size Lets You Plug it and Forget it, Ideal for Raspberry Pi / Pi2, Supports Windows, Mac OS, Linux(https://www.amazon.com/gp/product/B003M ... 0DER&psc=1)
- AmazonBasics 4-Port USB 2.0 Ultra-Mini Hub(https://www.amazon.com/gp/product/B003M ... 0DER&psc=1)
- Panlong Bluetooth OBD2 OBDII Car Diagnostic Scanner Check Engine Light for Android - Compatible with Torque Pro(https://www.amazon.com/gp/product/B00PJ ... HH7I&psc=1)
Please let me know of any possible compatibility issues
Return to “Media centres”
