raspberryjam6541
Install VNC Server On Kodi On A Raspberry Pi
Tue May 09, 2017 1:28 am
I have created a Kodi addon which uses dispmanx VNC Server which allows you to remotely control your Kodi media center. It should run on any Raspberry Pi 3 running Kodi Krypton or newer. I have tested it on a Raspberry Pi 3 B+ running OSMC, OpenELEC, LibreELEC, and Jessie Lite with Kodi installed. It only runs at about 1-3fps, but i still use it a lot. Get the addon at: https://raw.githubusercontent.com/sean6 ... em.vnc.zip or download my repository at: https://raw.githubusercontent.com/sean6 ... i.sean.zip. There is no password or ssl so do not run it outside of a firewall.
orak
Re: Install VNC Server On Kodi On A Raspberry Pi
Sat Mar 17, 2018 9:40 pm
Hi Sean,
I have tried to install your addon and have no problems. I have used the version out of the zipfile not the repository.
Kodi shows it as running. I use kodi on raspbian and start it from the command line.
But I can't get a connection and nmap to the ip of the pi shows only the ports 22 53 8080 and 9090 open no port 5900 I would expect for vncserver.
Could you give me a hint?
Karsten
raspberryjam6541
Sun Mar 18, 2018 7:38 pm
Try using port 0.
orak
Sun Mar 18, 2018 8:38 pm
Hello Sean,
in the moment the pi is down - weekend is over :-( - I will try it next week I hope,
and I also look for the logfile.
Thanks for your answer
Karsten
orak
Mon Mar 19, 2018 6:37 pm
Hello Sean,
I've tried it, but no result, even not in the log files.
So I've started kodi from a ssh session and it says
/home/pi/.kodi/addons/service.system.vnc/bin/vncserver: error while loading shared libraries: libGLESv2.so: cannot open shared object file: No such file or directory
so I've linked them, just take one found in chromium browser:
[email protected]:/usr/lib $ sudo ln -s chromium-browser/libGLESv2.so .
[email protected]:/usr/lib $ sudo ln -s chromium-browser/libEGL.so .
Now I 've get the following if I start kodi:
Open display[0]...
Display is 1280 x 720
Server bpp:16
Server bigEndian:0
Server redShift:0
Server blueShift:10
Server greeShift:5
19/03/2018 19:31:07 Listening for VNC connections on TCP port 5900
19/03/2018 19:31:07 Listening for VNC connections on TCP6 port 5900
open /dev/uinput returned -1.
First write returned -1.
ioctl UI_DEV_CREATE returned -1.
Error create uinput device -1.
As expected the server listens on 5900 but he does not do :-(
nmap shows no open port 5900 and connection is not possible.
Any ideas? I do a quick search but found no hint with dispmanx vncserver and the error about uinput device.
Karsten
orak
Wed Mar 21, 2018 8:24 pm
ok, I just try the hard way : sudo chmod go+rw /dev/uinput
and I can connect to the pi with krdc (vncviewer), the realvncviewer does not work
Karsten
doktour
Mon Apr 30, 2018 2:48 pm
Thank you for the addon. Works great!!!
Anything I can do to allow for shared clipboard between windows realvnc viewer and your addon? Would make it easier to enter urls etc.
Thank you
No1be4me
Thu Oct 25, 2018 3:25 am
Hi Sean,
It this addon still available, will like to try it on my Kodi installed on Pi. The links is not working.
Return to “Media centres”
