aegidius
DVD drive with USB micro-B cable?
Mon Dec 04, 2017 11:51 pm
Looking for a cheap external USB DVD drive that has a micro-B socket on the back (most have the old square B that I have seen). Are these common/rare/nonexistent?
Reason for asking is to try and power one with a PiDrive cable, in an HTPC build.
Imperf3kt
Re: DVD drive with USB micro-B cable?
Tue Dec 05, 2017 2:19 am
I believe the designs transitioned directly from mini USB to USB 3.0 and now, some USB C.
If they're USB 3.0, you might be lucky, the spec uses a standard micro USB B on one half of the plug and power on the other half via another USB style I forget the name of for power.
Anyway, if you have both cables, you can use them (sacrificing 2 USB ports) or just use a proper USB 3.0 cable
Be absolutely sure you have the right cable though.
https://en.wikipedia.org/wiki/USB_3.0#Pinouts
User experiencing technical difficulties.
aegidius
Tue Dec 05, 2017 12:57 pm
Just found this for any slim SATA drive:
https://www.ebay.com.au/itm/New-USB-3-0 ... 2692341082
This should do the trick...
drgeoff
Thu Dec 07, 2017 12:24 am
Like many of imperf3kt's answers on these forums this one matches his username.
A look at eg http://pinoutguide.com/visual/gen/micro ... nector.jpg will show that the added half (compared to USB 2.0 5-pin micro-USB) carries data and no 5 volts.
But yes, the 'old half' is physically and electrically compatible with USB 2.0 micro-USB specs and the device should be backwards compatible to work in USB-2 mode if connected with a USB 2.0 USB to micro-USB cable.
Imperf3kt
Thu Dec 07, 2017 3:06 am
Ah yeah, sorry, I misworded my original post and after verifying my mistake I forgot to edit things >.<
In the most basic sense, you can use a USB3.0 device, over a Micro B USB cable.
Return to “Media centres”
Who is online
Users browsing this forum: No registered users and 6 guests
