Kilheure
Update to Kodi 17 - deb command not found
Wed Oct 11, 2017 12:43 pm
Hi all,
I am a beginner with Rasbian and I try to update Kodi.
In the terminal, I already ran successfully
sudo apt-get update
sudo apt-get upgrade
sudo nano /etc/apt/sources.list
However, I have an issue with
 deb http://pipplware.pplware.pt/pipplware/dists/jessie/main/binary /
as terminal says deb: command not found.
Reading some forum, it says that I should use a text editor. I know there is OpenOffice in but it will not execute the line as terminal would. So, I am bit confuse here. How can I execute this line using terminal?
Re: Update to Kodi 17 - deb command not found
Wed Oct 11, 2017 1:46 pm
nano is the text editor. When you type sudo nano /etc/apt/sources.list it should pull in the file and you can add that line on the end.
Kilheure
Wed Oct 11, 2017 3:17 pm
Thanks for support, exactly what I needed to get further!
Return to “Media centres”
Who is online
Users browsing this forum: No registered users and 5 guests
