Hi all
Does anyone have a very quick implementation of a jpg gallery web page for all images within a given directory?
I'm guessing that a periodic cron job to run a Python script (using PIL perhaps) to create the thumbnails may work, but I've no idea on the next steps in getting the resultant batch to display on a Web page: the quantity and file references would clearly be variable. The full size jpg would also need to be displayed on selection.
Any ideas?
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Re: Basic thumbnail gallery view
Warning, ugly PHP code alert!
You'll need to do something special to build the thumbnails, that ugly PHP program generates HTML wrapped round the full size images.
The basic principle is find the filename wrap <LI>... </LI> and <IMG SRC=....> tags round it.
<?php function iterateDirectory($i)
echo '<ul>';
foreach ($i as $path) {
if ($path->isDir())
iterateDirectory($path);
else
if (strpos($path, '.jpg')) {
$output = array();
$chunks = explode('/', $path);
foreach ($chunks as $i => $chunk) {
array_push($output, $chunk);
echo '<li><img src=..'.join("/",$output).'></li>';
echo '</ul>';
# beware the hard coded directory name.
$dir = '/var/www/httpi/pics';
$iterator = new RecursiveIteratorIterator(new RecursiveDirectoryIterator($dir));
iterateDirectory($iterator);
