tomaok
[SOLVED]Measure execution time inside Shell script
Fri Dec 20, 2013 11:16 am
Hi world,
I 've a problem with using the time program inside a Shell script.
On command line its working well an d give me the execution time of my code.
But inside Shell script :
./test2.sh: time: not found
whereis time ? it gives me nothing see below!
[email protected] ~ $ whereis time
time: /usr/include/time.h /usr/share/man/man7/time.7.gz /usr/share/man/man2/time.2.gz
"FIND" gives me this ??
[email protected] ~ $ sudo find / -name time
/sys/module/printk/parameters/time
So who knows whereis "time" ? an alias toward another program ??
But perhaps you have a better way to measure execution time (in ms please)inside a Shell script ??
Thank you for any help
Tom Aok
scrapheap
Re: Measure execution time inside Shell script
Fri Dec 20, 2013 2:25 pm
Sometimes the time command isn't present in the filesystem, instead some OSs choose to rely on bash's builtin in commands. Check if your shell script is set to use bash or something else? Specifically check the first line and if it says:
#!/bin/sh
Then change it to:
#!/bin/bash
and see if it makes a difference.
tomaok
[SOLVED]Re: Measure execution time inside Shell script
Fri Dec 20, 2013 9:11 pm
Wonderfull
it works with #!/bin/bash
Thank you very much
:D
