yonubear
Lua cpu usage
Wed Nov 20, 2013 9:15 pm
question here for you Pi folks I have installed lua on my Pi to work with the GPIO I need to ask a stupid question I will be monitoring several reed switches so for CPU usage should I use while loops or if statements as about 80% of the time the status of the switches will not change.
Sorry I know this is a odd question,
Yonu
Re: Lua cpu usage
Wed Nov 20, 2013 9:42 pm
There are two ways to deal with a GPIO signal when you don't know when it's due to arrive.
  1. Spin in a loop testing the pin until it changes
  2. Sit in a wait until an interrupt posts you as ready
Clearly the second option is better because while you're in a wait-state your processor can be doing something else that's productive. The first option will tend towards 100% cpu busy. You can include a sleep(...) function but you may miss the signal arriving.
So you need to explore whether your Lua GPIO library can handle interrupt driven processes or not. If not, switch to python or c/c++ which can handle interrupts.
This is a doctor free zone.
DavidS
Re: Lua cpu usage
Thu Nov 21, 2013 12:20 am
yonubear wrote:question here for you Pi folks I have installed lua on my Pi to work with the GPIO I need to ask a stupid question I will be monitoring several reed switches so for CPU usage should I use while loops or if statements as about 80% of the time the status of the switches will not change.
Yonu
As you state Lua I am going to assume that you are using RISC Lua on RISC OS with the GPIO Module installed and are using the SWI implementation in RISC Lua to call to it. Now with these assumptions I think it would be more effecient to use a callback, though I believe that this would take an exorbant amount of code to set up for doing something so simple.
yonubear
Re: Lua cpu usage
Thu Nov 21, 2013 12:29 am
ok actually I am running Raspbian with lua 5.1 installed and I compiled the GPIO module found here http://www.andre-simon.de/doku/rpi_gpio ... o_lua.html
the main reason I am using Lua is for the use of Xpl well that and all my other automation code for other software is in Lua
Re: Lua cpu usage
Thu Nov 21, 2013 7:35 am
As far as I know there is no way to get an interrupt from a pin to execute a Lua function.
That means you will have to poll the pin state at regular intervals. That means your CPU usage will go to 100% unless you have a sleep in there somewhere. Then CPU usage will depend on how often you do the polling.
Presumably your program has a main loop and you can just read the pin somewhere in there. So the answer seems to be that you will have a "while" or other loop construct and "if" to test the pin state.
yonubear
Re: Lua cpu usage
Thu Nov 21, 2013 1:10 pm
Ok thanks would you know if there is a xpl module for Python? As I would prefer interuppts after reading about them
Re: Lua cpu usage
Thu Nov 21, 2013 3:51 pm
