Rolly
Re: Mono (C#) 2.11.4 hard-float for Raspberry Pi (EXPERIMENT
Fri Nov 08, 2013 10:52 pm
SpawnSP was absolutely right (even if what was happening failed the principle of least astonishment to this Unix newbee). I had one bad download file, & every download after that was downloaded as file.n
Each time I went to uncompress, it would use the original bad file.
Thx 4 the help.
deandob
Sat Nov 23, 2013 12:00 am
Thank you for the link to a new hard float version, it's good news as .NET on ARM devices should be a popular option.
I had a look at the github and for a Linux newbie like me the dependencies & compilation looks daunting - would it be possible for someone to compile the binaries and zip/upload them? I would normally try myself but I find anything serious with Linux requires a lot of time & effort (try something, it fails, research why, try something different, loop until I get it right....)
Generoso
Tue Dec 31, 2013 5:37 pm
Mono 3.2.7 for Raspberry Pi (hard float debian)
https://sourceforge.net/projects/homege ... ono-armhf/
see README for install instructions.
Cheers,
Gene.
xfx
Tue Dec 31, 2013 5:48 pm
Wow! Thank you Gene for such a great new year's gift!
xfx
Tue Dec 31, 2013 7:06 pm
Gene,
Is there any chance to have "Microsoft.VisualBasic" compiled and included in the DEB package?
Generoso
Tue Dec 31, 2013 7:34 pm
Didn't know VB.Net come as a separate module:
http://stackoverflow.com/questions/2965 ... et-support
I'll try to update the deb package adding VB support the next week.
Gene.
xfx
Fri Jan 03, 2014 1:03 am
Thank you very much Gene.
If you think there's anything I can help with, please, just let me know.
Generoso
Sat Jan 04, 2014 11:55 pm
Uploaded mono-basic package. Didn't test it though.
Cheers,
g.
xfx
Sun Jan 05, 2014 12:08 am
Great!
Downloading right now -- I'll let you know if it works.
xfx
Sun Jan 05, 2014 12:43 am
Gene,
It installed perfectly but I had to do the following in order to be able to run a WinForms application:
sudo apt-get install libgdiplus
sudo ln -s /usr/lib/libgdiplus.so /usr/local/lib/libgdiplus.so
I don't know why the last command is necessary, but it was a quick fix so that mono can locate the libgdi library in the /usr/local/lib folder.
ReBoot
Tue Apr 01, 2014 2:22 pm
Generoso wrote:Uploaded mono-basic package. Didn't test it though.
Cheers,
g.
The "/mono-armhf" file could not be found or is not available. Please select another file.
simonmcc
Tue Apr 01, 2014 2:40 pm
Cheers,
g.
It has moved location by the look of things:
http://sourceforge.net/projects/homegen ... ono-armhf/
simonmcc.blogspot.com/search/label/pi
ReBoot
Tue Apr 01, 2014 2:57 pm
Cheers,
g.
Ah, nice. Will try it later at home.
Generoso
Tue Apr 01, 2014 3:45 pm
This is not needed anymore.
Just use the official mono package from the latest raspbian distribution.
g.
zezba9000
Tue Apr 01, 2014 6:11 pm
Yep Mono3.4 just came out with some more ARM HF fixes I think.
I hope this version is in the repo.
Huk
Fri Apr 04, 2014 5:15 am
I don't see Mono 3.4 in Raspbian repos - does anybody know when will it be available?
shahroozmufi
Mon Apr 28, 2014 10:13 am
at last i reach this point after all these installer steps for mono and gtk# and other tales..........:,,and i face planted to ground
after thsi command:
sudo mono hellogui.exe
mono: symbol lookup error: /usr/local/lib/libglibsharpglue-2.so: undefined symbol: g_thread_supported
any help
venkarip
Tue May 13, 2014 11:58 am
It complained when I used sudo too. Have you tried without sudo?
mono hellogui.exe
shahroozmufi wrote:at last i reach this point after all these installer steps for mono and gtk# and other tales..........:,,and i face planted to ground
after thsi command:
any help
