GTRDRIVER
Perl - Hangup ?
Thu Mar 14, 2013 8:40 am
Hello
im using 3 RPI´s for different small projects - now i have a Projekt with Perl.
I´m using the RPI in the default Config with Raspian Wheezy.
It was possible to install Perl using APT without any Problems - but as soon i want to using CPAN to install any Perl Module the RPI hangup and i only can diconnect the Power to reanimate it.
Any ideas whats going wrong here ?
Best Regards
GTR
scrapheap
Re: Perl - Hangup ?
Fri Mar 15, 2013 9:13 am
A few questions that might help
* What CPAN modules are you trying to install?
* At what stage of installing from CPAN do you encounter it locking up?
* Does the whole machine lock up or can you open another shell?
* Does it lock up when installing Pure Perl modules or only when it requires some C compiling?
GTRDRIVER
Re: Perl - Hangup ?
Fri Apr 05, 2013 9:02 pm
Hi
I just want to inform you and perhaps other ones who have the same Problem that there is a simple solution.
Im now using "cpanm" to install perl Modules - with this little helper everything works fine.
Best regards
GTR
