peli44
Check networkconnection with Javascript
Sun Feb 24, 2013 9:32 pm
I am using a local webpage that starts when I boot the system. On that page I use Javascript.
The first thing I want to do is to check if the raspberry pi is connected to the LAN via Ethernet. I thought I could use this construction. I am using jQuery.
if (navigator.onLine == true)
connectStatus ="online";
else
connectStatus ="offline";
It works ok when I run it on my Mac but not on the Raspberry PI. On the Raspberry I always get the answer "online".
/Per
myminimonster
Re: Check networkconnection with Javascript
Thu Feb 28, 2013 3:21 am
There is a mention here of a bug that linux always reports online.
https://developer.mozilla.org/en-US/doc ... tor.onLine
Maybe you could considering using a different language to do this.
I had a lot of stability issues with my pi so i set up a script that ran as a crontab and updated my db as to whether the pi could ping my router.
this way i was able to see when and if there was a pattern to my pi going offfline
Here is the python script i use.
#!/usr/bin/python
# coding=UTF-8
import MySQLdb
import sys
import datetime
import subprocess
import shlex
command_line = "ping -c 1 192.168.0.1"
args = shlex.split(command_line)
try:
        db = MySQLdb.connect (host = "localhost", user = "xxxx", passwd = "xxxxx", db = "xxxxxxx")
#       print "connected"
except:
    print "Error "
    sys.exit (1)
now = datetime.datetime.now()
now1 = now.strftime("%Y-%m-%d %H:%M")
cur = db.cursor()
try:
        subprocess.check_call(args,stdout=subprocess.PIPE,stderr=subprocess.PIPE)
        cur.execute("INSERT INTO tablename(row1, row2) VALUES(%s, 'ping alive')", now1)
        db.commit()
except:
        cur.execute("INSERT INTO tablename(row1, row2) VALUES(%s, 'ping dead')", now1)
        db.commit()
db.close ()
Adrian
Newbie
scrapheap
Thu Feb 28, 2013 10:02 am
navigator.onLine is known to lie on some browsers. If it is is false then you are pretty sure to be offline, if it is true then you may or may not be online (depending on the browser). A sensible thing to do after discovering that navigator.onLine is true would be to make a http request to known web page and see if it fails.
Check out http://ednortonengineeringsociety.blogs ... tml-5.html for an example.
katanac
Fri Mar 08, 2013 4:11 am
A better option would be to use node.js, and leverage the builtin os module.
Check: http://nodejs.org/api/os.html
os.networkInterfaces() would be quite useful for this circumstance.
