tonyhughes
BASH script to check for Pi hardware and/or Raspbian
Fri Feb 22, 2013 2:08 am
I have a few routines in my software that are very Pi specific, but I would like to make the rest of it okay for x86 Debian based systems too.
I can check for the arm hardware with:
#! /bin/bash
WHAT_AM_I=$(uname -m)
echo "$WHAT_AM_I"
Which returns "armv6l".
Is that good enough to reliably determine we are running on a Pi?
I would also like to get more adventurous, and make my script work for different OSes on the Pi too - it is currently aimed at Raspbian, but if I can detect a different OS, then I can run routines specific to that OS (i.e. using pacman or yum instead of apt).
How can I reliably determine the OS breed. Preferably with a routine that will survive OS version number updates...
e.g. I'd like to create a variable who's contents are "Arch" or "Fedora" or "Raspbian" etc.
jojopi
Re: BASH script to check for Pi hardware and/or Raspbian
Fri Feb 22, 2013 4:05 am
To check specifically for a Pi (or very authentic clone) look at the Hardware and Revision lines in /proc/cpuinfo. But "uname -m" is better if you just want i686/x86_64/arm*.
You might want to know if the user-space ARM binaries are compiled for hard float. "readelf -a /proc/self/exe |grep Tag_ABI_VFP_args" will be non-empty if readlink is.
Debian/Raspbian systems will have a file /etc/debian_version (giving 7.0 for wheezy). Fedora-based systems have a slightly more verbose /etc/redhat-release (actually a symlink to fedora-release, unless you are running Red Sleeve). Arch has an empty file /etc/arch-release.
tonyhughes
Fri Feb 22, 2013 6:59 am
So massively incredibly helpful - thankyou!
gordon@drogon.net
Fri Feb 22, 2013 10:30 am
I used this for a project recently:
grep -q BCM2708 /proc/cpuinfo
Seemed to work well enough to let my project build script know if it was on a Pi or not. (check the exit code)
-Gordon
dr_d_gee
Fri Feb 22, 2013 3:05 pm
There are also other options to uname, as you may already be aware.
uname -o
prints the operating system (I'm not on a Linux box at the moment so can't say exactly what it prints) and
uname - r
prints the kernel release. There are others; see http://linux.about.com/library/cmd/blcmdl1_uname.htm (or other sources). I *think* the kernel release output usually prints the distribution name (among other things).
tonyhughes
Fri Feb 22, 2013 9:42 pm
Thanks. For those playing at home, here is the output on a Pi.
tony@orangepi ~ $ uname -o
GNU/Linux
tony@orangepi ~ $ uname -r
3.6.11+
tony@orangepi ~ $
gordon@drogon.net
Fri Feb 22, 2013 9:44 pm
dr_d_gee wrote:There are also other options to uname, as you may already be aware.
uname -o
uname - r
I went through that too - I didn't find uname that enlightening - uname -o yeilds "GNU/Lunux" on a Pi, and the same on my x86 workstation.. -r isn't much help either - unless you're targetting a particular kernel release.
uname -m
Might be the closest though - you get armv6l on the Pi and i686 in my workstation, however I also get x86_64 on a 64-bit machine I am also using in my build process for the same project which wasn't what I was after, so I stuck with grepping for the hardware type in /proc/cpuinfo
I'm not even sure if there is a standard way to determine if your on Debian, Raspbian, RedHat Centos, Ubuntu either.. I saw some scripts a while back that simple looked for various files in existance to try to work out what the distro was.
-Gordon
ukscone
Fri Feb 22, 2013 10:03 pm
you could try
cat /etc/*-release
and/or
python -c "import platform; print platform.dist()"
won't work everywhere & probably not too trustworthy but might be enough
ahundt
Sun Aug 12, 2018 5:49 pm
This isn't 100% bash, but python comes on the pi so this should work on the pi & I have a check if python exists so it should not run on anything that does not have python! So hopefully this is pretty cross platform compatible! worked for me, ymmv.
# check if it is a raspberry pi, because we'll need a special ruby first
if [ -x "$(command -v python)" ] ; then
    R_PI=`python -c "import platform; print 'raspberrypi' in platform.uname()"`
    if [ "$R_PI" = "True" ] ; then
        # put your raspberry py code here, in my case I upgrade the ruby version:
        # run ruby upgrade script. source: https://gist.github.com/blacktm/8302741
        yes | bash <(curl -s https://gist.githubusercontent.com/blacktm/8302741/raw/install_ruby_rpi.sh)
    fi
fi
jahboater
Mon Aug 13, 2018 7:13 am
Slightly OT, but you might also be interested in:
/proc/device-tree/model
which provides the full model name as a NUL terminated string.
pi@Pi3:~ $ cat /proc/device-tree/model
Raspberry Pi 3 Model B Plus Rev 1.3
LewisCowles1986
Sun May 31, 2020 9:05 pm
2020 Update Here. It's looking like I'm going to have to implement quirks for some software on rpi4 to overcome aarch64 binaries failing to run with
"No such file or directory"
egrep -q "BCM(283(5|6|7)|270(8|9)|2711)" /proc/cpuinfo
if
is zero once this has run, then you should be on a Pi or compatible SoC
trejan
Sun May 31, 2020 9:17 pm
Huh? Never seen that before.
if
The Linux kernel has shown only BCM2835 in /proc/cpuinfo for every Pi SoC for several years now.
Milliways
Mon Jun 01, 2020 1:38 am
should report model, which is easily parsed.
I use the following script to display useful info about Pi - it should work on most Linux OS (although some Raspbian specific entries don't work)
about
bls
Contact: Twitter
Mon Jun 01, 2020 2:46 am
You could also look at /etc/os-release. On the very latest 2020-05-27 release, /etc/os-release has
rpi44~# cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
rpi44~# uname -a
Linux rpi44 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
I'm guessing that some of these fields will change in a future release from "Raspbian" to something else, but for now, this should work. Most distros seem to have this file, and if it doesn't, you'll know that it's not Raspbian or or RaspiOS32.
Pi tools:
Free your network from your router's DHCP/DNS and run it on a Pi:https://github.com/gitbls/ndm
Quickly and easily build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
