jimb137
greenfoot installation
Wed Jan 16, 2013 3:47 pm
anybody know how to get greenfoot working on the Pi? I've downloaded the Oracle jdk (softfloat) and the greenfoot.jar, but all I get after that is errors.
Help!!!
-rst-
Re: greenfoot installation
Wed Jan 16, 2013 4:22 pm
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
DrPiD
Wed Apr 17, 2013 9:58 am
This is an old thread, but I managed to get it up and running and thought it might be useful for future reference.
I grabbed Oracle JDK 8 (with JavaFX) for ARM Early Access
Created a directory to install the JDK to:
mkdir -p /opt
Decompress the JDK:
sudo tar zxvf (name of package) -C /opt
Make sure it's in the right place, this should return the version:
sudo /opt/jdk1.8.0/bin/java -version
Now that the Java JDK is installed you can go ahead and grab Greenfoot.
Download the Pure Java version
Greenfoot is installed using the command:
sudo /opt/jdk1.8.0/bin/java -jar /home/pi/Greenfoot-generic-221.jar
It should pop up a window that's prepopulated with the JDK location and where you want to install Greenfoot to.
Once it's installed, if you left it on default settings, you can run it from the greenfoot script in the /home/pi/greenfoot folder or using the ./greenfoot command from within the /home/pi/greenfoot directory!
Hope this is useful :)
Community Manager - IndieCity
