KG2V
.Net Core 3.x, Display Brightness
Fri Jan 08, 2021 4:45 pm
Hi folks,
I'm looking to adjust the display brightness (official display, current rev) on Raspian, using .NET core 3.x
Anyone have any clue how to do this? I've seen various other languages, and there doesn't seem to be a .NET core/Raspian group here (just win10IoT (not going there ever again)
Charlie
ProjectMayu
Re: .Net Core 3.x, Display Brightness
Thu Jan 14, 2021 7:49 pm
Have a look in the folder /sys/class/backlight/rpi_backlight/ and just google the full path to any file in there to find documentation
Try /sys/class/backlight/rpi_backlight/actual_brightness
use 0 to 255
return Byte.Parse(System.IO.File.ReadAllText("//sys//class//backlight//rpi_backlight//actual_brightness"));
and
System.IO.File.WriteAllText("//sys//class//backlight//rpi_backlight//actual_brightness", value.ToString(), Text.Encoding.GetEncoding(1252))
KG2V
Tue Jan 26, 2021 7:23 pm
Trying to change the file, (using nano as sudo) and you can't write to the file. Joy
