YoshiFan100
Perl Controlling Gpio
Sat Jan 04, 2020 9:13 pm
I am interested in learning Perl, and wonder how to control the raspberry pi 4s gpio pins with perl, such as blinking an led. I was wondering if there is a library or something similar that I could use for perl. Thanks!
YoshiFan100
Re: Perl Controlling Gpio
Sat Jan 04, 2020 9:40 pm
I used the first link, and I downloaded like how the instructions said. However when I try to run the perl file in geany ide, I get the following error message.
 Can't locate Device/BCM2835.pm in @INC (you may need to install the Device::BCM2835
How do I solve this error message? Thanks!
joan
Sat Jan 04, 2020 10:00 pm
I have no idea, I don't use those PERL modules.
scruss
Sat Jan 04, 2020 11:22 pm
You need to install the support library first from the BCM 2835 support page.
Then you'd install the module with
sudo cpan Device::BCM2835
It seems a little old, so may not work on newer Raspberry Pis.
YoshiFan100
Sun Jan 05, 2020 2:25 am
It does seem old. It did not work. Seems like a lot of the GPIO libraries only work on older pis. I will try to find a different library.
Sun Jan 05, 2020 8:00 am
I suspect you will need to sharpen your coding pencil. There's very few folks who've ever twiddled GPIOs with Perl.
This is a doctor free zone.
jahboater
Sun Jan 05, 2020 8:27 am
Or consider a more common choice for GPIO access such as Python or C.
joan
Sun Jan 05, 2020 10:11 am
The one which uses my pigpio daemon seems to work. It certainly toggles a GPIO.
https://metacpan.org/pod/RPi::PIGPIO
scruss
Sun Jan 05, 2020 3:29 pm
Yeah, but none of them are Perl. It's still the language that gives me the most delight to use.
Even the RPi::PIGPIO library looks a little under-maintained, but I'm glad it works.
