prem111
Two servos in perl example.
Sat Dec 28, 2019 2:22 pm
Hi. I would like an example of using 2 servos via gpio (PWM) in perl. Thanks.
im use:
use Term::ReadKey;
use WiringPi::API qw(:all);
use RPi::Const qw(:all);
use Math::Round;
use constant {
MIN => 130,
MAX => 210,
ESC1_PIN => 12,
ESC2_PIN => 6,
NEUTRAL => 161,
RANGE => 2000,
SKIP => 1,
setup_gpio();
pin_mode(ESC1_PIN, PWM_OUT);
pin_mode(ESC2_PIN, PWM_OUT);
pwm_set_mode(PWM_MODE_MS);
pwm_set_clock(NEUTRAL);
pwm_set_range(RANGE);
pwm_write(ESC1_PIN, 176);
pwm_write(ESC2_PIN, 176);
But not working...
scruss
Re: Two servos in perl example.
Sat Dec 28, 2019 3:30 pm
What are the error messages?
What's your wiring like?
Do you have enough power to drive the servos? Can you get one servo to work?
prem111
Sat Dec 28, 2019 3:35 pm
There are no errors. Both ESCs just don't work. When he hash
#pin_mode (ESC2_PIN, PWM_OUT);
and
#pwm_write (ESC2_PIN, 176);
First ESC works fine.
That's exactly what ESC is about, I wrote a servo for example.
prem111
Sat Dec 28, 2019 6:18 pm
Ok problem solved. The problem was wrong connection of the PWM pins.
I have one more question, what is the solution for pwm software? I know there are two pwm hardware outputs. I need more. Do I have to use the rpi::pigpio library? I don't want to run daemons.
joan
Sat Dec 28, 2019 6:22 pm
As you say there are two hardware PWM channels. You will have to use software PWM for any additional ESCs. Unless there is a RPIO module for PERL (n.b. RPIO, not RPi.GPIO).
prem111
Sat Dec 28, 2019 6:29 pm
Is there something for RPIO in perl?
prem111
Sat Dec 28, 2019 7:50 pm
i found only RPi::PIGPIO with daemon pigpiod, but write_pwm function is only for volate level for pins.....
Sun Dec 29, 2019 1:38 am
What Raspberry Pi are you using?
What OS?
Does your unsupported perl WiringPi module have a hack for your RPi model? Hint: WiringPi is sensitive to RPi models and even the last version (v2.52) won't work on a RPi 4B 4GB v1.2.
This is a doctor free zone.
prem111
Sun Dec 29, 2019 11:08 am
Rpi 3b
Os: Linux raspberrypi 4.19.75-v7+
Im trying RPi::WiringPi perl module, but I don't see the possibility of assigning pwm to any pin (as pwm software).
Pigpio run as a daemon works fine (with the pigs bash-command).
joan
Sun Dec 29, 2019 11:23 am
The obvious solutions for additional hardware PWM on the non-PWM GPIO are RPIO, servoblaster, and pigpio.
RPIO would be a non-daemon solution but there does not appear to be a way to use it from PERL.
servoblaster and pigpio are both daemon based. However servoblaster is a lot "lighter" than pigpio. Both servoblaster and pigpio offer a pipe based command interface which will be accessible from PERL.
