John_Spikowski
Swift RPi
Sun Nov 17, 2019 8:17 am
Swift RPi
I was able to install Swift as a pre-built binary distribution for the RPi. This LINK is the project repository. You can install the binaries or build it yourself.
I took a peek at Swift for Ubuntu about 5 years ago. It was at version 2.1 at that time. It is now at 5.1.
The Swift Programming Language
Swift GPIO
Using Legacy C APIs with Swift
[email protected]:~/swift-dev $ swift --version
Swift version 5.1.1 (swift-5.1.1-RELEASE)
Target: armv7-unknown-linux-gnueabihf
[email protected]:~/swift-dev $ cat hello.swift
print("Hello Swift")
[email protected]:~/swift-dev $ swift hello.swift
Hello Swift
[email protected]:~/swift-dev $ swiftc hello.swift -o hello
[email protected]:~/swift-dev $ ./hello
Hello Swift
[email protected]:~/swift-dev $ ls -l
total 16
-rwxr-xr-x 1 pi pi 10032 Nov 15 19:38 hello
-rw-r--r-- 1 pi pi    21 Nov 15 19:35 hello.swift
Swift Value Diff
func value_diff(nums: [Int]) -> Int {
    var min_num = nums[0]
    var max_num = nums[0]
    for x in 0..<nums.count
        min_num = min(nums[x], min_num)
        max_num = max(nums[x], max_num)
    return max_num - min_num
print(value_diff(nums: [-5, -3, -7, 0]))
print(value_diff(nums: [8, 2, 14, 24]))
print(value_diff(nums: [1, 0, 6, 3]))
Output
[email protected]:~/swift-dev $ time swift value_diff.swift
7
22
6
real	0m0.471s
user	0m0.373s
sys	0m0.100s
[email protected]:~/swift-dev $ swiftc value_diff.swift -o vd
[email protected]:~/swift-dev $ time ./vd
7
22
6
real	0m0.026s
user	0m0.008s
sys	0m0.018s
Last edited by John_Spikowski on Tue Nov 19, 2019 2:06 am, edited 5 times in total.
Re: Swift RPi
Sun Nov 17, 2019 5:56 pm
My comment was about programming with Swift. Totally on topic.
I don't think a plan by one person, Apple, can be called a conspiracy. Does that not take two or more?
But OK, carry on, I'll keep out of it.
John_Spikowski
Re: Swift RPi
Sun Nov 17, 2019 9:47 pm
Here is a recursive fibo 24 in Swift. There is a nice BIGINT and GMP Swift extensions available if one would like to take a shot at the 1 mil fibo challenge.
/* Basic fibonacci function in swift.
   Demostrates func calls and recursion.
func fibonacci(i: Int) -> Int {
    if i <= 2 {
        return 1
    } else {
        return fibonacci(i:i - 1) + fibonacci(i:i - 2)
print(fibonacci(i:24))
Output
[email protected]:~/swift-dev $ time swift fiborecursive.swift
46368
real	0m0.434s
user	0m0.333s
sys	0m0.102s
[email protected]:~/swift-dev $ swiftc fiborecursive.swift -o fibos24
[email protected]:~/swift-dev $ time ./fibos24
46368
real	0m0.029s
user	0m0.010s
sys	0m0.019s
Re: Swift RPi
Sun Nov 17, 2019 10:21 pm
Be aware that the Million Digit Fibonacci Challenge to which John refers specifies that solutions use only a single language and do not make use of non-standard libraries.
https://github.com/ZiCog/fibo_4784969/b ... /README.md
It would be interesting though to see the big number arithmetic required for the challenge done in Swift. The Karatsuba multiplication for example.
John_Spikowski
Re: Swift RPi
Sun Nov 17, 2019 10:31 pm
I will posting a SQLite3 Swift example AIR did for Ubuntu. Using C libraries with Swift isn't that difficult.
I believe the BIGINT extention is written in Swift.
Swift BigInt
Re: Swift RPi
Sun Nov 17, 2019 10:50 pm
That does indeed include a multiplication using the Karatsuba algorithm.
It would be interesting to see a Swift Million Digit Fibo solution using that.
John_Spikowski
Re: Swift RPi
Sun Nov 17, 2019 11:07 pm
Are you interested enough to write the code to do it or hoping I or someone else will satisfy your curiosity?
Re: Swift RPi
Sun Nov 17, 2019 11:12 pm
As you have taken the trouble to start a Swift thread and brought up the Fib challenge I assumed you would be chomping at the bit to get on with it.
John_Spikowski
Re: Swift RPi
Sun Nov 17, 2019 11:21 pm
I'm the Swift messenger not its maintainer.
John_Spikowski
Re: Swift RPi
Sun Nov 17, 2019 11:50 pm
As a reference, here is the same in C BASIC.
C BASIC is C dressed in BASIC.
#include <stdio.h>
#include "cbasic.h"
FUNCTION int Fibonacci(int i)
BEGIN_FUNCTION
  IF (i <= 2) THEN
    RETURN_FUNCTION(1);
  ELSE
    RETURN_FUNCTION(Fibonacci(i - 1) + Fibonacci(i - 2));
  END_IF
END_FUNCTION
MAIN
BEGIN_FUNCTION
  PRINT ("%i\n",Fibonacci(24));
END_FUNCTION
Output
[email protected]:~/c-basic $ time ./fibocb
46368
real	0m0.008s
user	0m0.008s
sys	0m0.001s
John_Spikowski
Re: Swift RPi
Mon Nov 18, 2019 4:12 pm
AIR was kind enough to get me pointed in the right direction with current C package building. I was able to build a cool web server in Swift which I will be posting today.
Swift deprecates code faster than any language I have used. They are definitely fast tracking development. The bright side is their syntax and error reporting is some of the best I've run into.
Swift isn't a language to be ignored and if I were Python, I would be worried.
Re: Swift RPi
Mon Nov 18, 2019 4:28 pm
Had a quick tidy up of this thread.
Some of the post were practically asking for a temporary ban. People should know better. I've had my hot chocolate for the day, in a good mood, so count yourselves lucky.
That is all.
John_Spikowski
Re: Swift RPi
Mon Nov 18, 2019 4:47 pm
Honest, I wasn't looking for strike 3. I'm trying to keep this thread focused on the benefits of programming in Swift. Opinions should be posted somewhere else.
Re: Swift RPi
Mon Nov 18, 2019 5:20 pm
Your Swift fibo gives the wrong answer for n = 0. You could fix that using Swift's pattern matching syntax.
It also seems a bit slow. But it's a bit too small of a test case to tell. How about something we can measure properly, all the fibos from 0 to 42?
Rust on my Pi 3:
fn fibonacci(n: i32) -> i32 {
    match n {
        0     => 0,
        1..=2 => 1,
        _     => fibonacci(n - 1) + fibonacci(n - 2),
fn main () {
    for n in 0..=42 {
        println!("fibo({}) = {}", n, fibonacci(n));
$ rustc  -C opt-level=3   fibo.rs
[email protected]:~ $ time ./fibo
fibo(0) = 0
fibo(1) = 1
fibo(2) = 1
fibo(3) = 2
fibo(4) = 3
fibo(5) = 5
fibo(37) = 24157817
fibo(38) = 39088169
fibo(39) = 63245986
fibo(40) = 102334155
fibo(41) = 165580141
fibo(42) = 267914296
real    0m18.543s
user    0m18.529s
sys     0m0.010s
Re: Swift RPi
Mon Nov 18, 2019 5:22 pm
You were not the standout...
John_Spikowski
Re: Swift RPi
Mon Nov 18, 2019 5:37 pm
Shocked!
A good Monday.
John_Spikowski
Re: Swift RPi
Tue Nov 19, 2019 1:34 am
To build the SQLite package for Swift, I used the PerfectSoft template method.
1, Clone THIS repo to a directory of choice.
2. cd to the Perfect-SQLite directory.
3. swift build
An added benefit of the PerfectSoft template is it adds a CRUD library as well.
CRUD is an object-relational mapping (ORM) system for Swift 4+. CRUD takes Swift 4 Codable types and maps them to SQL database tables. CRUD can create tables based on Codable types and perform inserts and updates of objects in those tables. CRUD can also perform selects and joins of tables, all in a type-safe manner.
CRUD uses a simple, expressive, and type safe methodology for constructing queries as a series of operations. It is designed to be light-weight and has zero additional dependencies. It uses generics, KeyPaths and Codables to ensure as much misuse as possible is caught at compile time.
Database client library packages can add CRUD support by implementing a few protocols. Support is available for SQLite, Postgres, and MySQL.
John_Spikowski
Re: Swift RPi
Tue Nov 19, 2019 5:12 pm
I'm able to create C library package interfaces without issue. What I can't seem to figure out is how to install and use them. My IMPORT statement fails saying it can't find the package. The PerfectSoft site makes it sound like that this should be obvious. (to everyone but me)
@amesh,
Thanks for turning down the heat.
John_Spikowski
Re: Swift RPi
Tue Nov 19, 2019 9:12 pm
I have been searching for what GUI options there may be for Swift on the RPi. Unless I'm missing something, you're on your own.
I was able to get IUP working with Swift on Ubuntu a few years back when it made its appearance on the open source scene. I ported IUP to the RPi recently and posted a few examples with my ScriptBasic binding.
I will see if I can make the IUP connection with Swift work on the RPi. The combo should be pretty sweet.
If I can get IUP working with Swift on the RPi, I may be able to get the IUP editor to work as an IDE. Getting ahead of myself but I thought I would share my thoughts and current direction with this effort.
John_Spikowski
Re: Swift RPi
Thu Nov 21, 2019 8:43 pm
Anyone with a Swift interest out there?
I could use a mentor for this thread.
If I can figure out how to install these C library packages so that an IMPORT finds them, I will create a project in the sandbox for them.
shaymanjohn
Re: Swift RPi
Fri Nov 22, 2019 10:11 am
Hi John,
By day I'm a Swift dev - iOS apps mainly, but also done some server side stuff using Kitura...
Would be happy to try help out - never done anything with C library packages in Swift, so this is all new to me too..
John_Spikowski
Re: Swift RPi
Fri Nov 22, 2019 5:05 pm
Welcome aboard!
Do you have Swift installed on your RPi?
Swift seems to have come a long way on Linux since I took a peek at it a few years ago when it was at version 2.1.
hippy
Re: Swift RPi
Sat Nov 23, 2019 6:21 pm
Or just correct the incorrect -
    if i <= 2 {
        return 1
to, correcting the comparison and returning 'i' rather than '1' -
    if i < 2 {
        return i
There's a reason I started using 'n' rather than 'i' as the default single letter variable name :P
Re: Swift RPi
Sat Nov 23, 2019 6:57 pm
hippy,
Not sure where you are drawing that conclusion from as, for Fibo(24)=46368 which seems to have become an adopted de-facto benchmark, Swift appears to be pretty quick -
I get it from measuring it.
The time reported by John_Spikowski for fibo(24) above on a Pi 4 is 0.029s.
The time I get in Rust 0.011 seconds. And that is on a Pi 3B !
$ cat fibo.rs
    match n {
        0 => 0,
        1..=2 => 1,
fn main () {
    let n = 24;
[email protected]:~ $ rustc  -C opt-level=3   fibo.rs
fibo(24) = 46368
real    0m0.011s
user    0m0.011s
sys     0m0.000s
C on my Pi 3 does it in 0.008 seconds:
 $ cat fibo.c
#include "stdio.h"
int fibonacci(int n) {
    if (n <2) {
        return n;
    return fibonacci(n - 1) + fibonacci(n - 2);
int main () {
    int n = 24;
    printf("fibo(%d) = %d\n", n, fibonacci(n));
[email protected]:~ $ gcc -Wall -O3 -o fibo  fibo.c
fibo(24) = 46368
real    0m0.008s
user    0m0.008s
sys     0m0.000s
Give that a Pi 4 is two or more times faster than a Pi 3 that makes John's Swift about 5 times slower.
The question then is, why are you getting a very different result than John?
Of course doing this is very silly. With such a short run time the figures are almost meaningless. It can happen for example that the processor does not have enough time to think about cranking it's clock rate up to do the job. Which has caught me out before.
hippy
Re: Swift RPi
Sat Nov 23, 2019 7:16 pm
hippy,
Yes; I deleted that from my earlier post when I realised I wasn't comparing like with like.
By the way, your correction for n = 0 is incorrect.
Are you sure ? It seems to work for me, giving 0, 1, 1, 2, 3, 5, 8, 13, 21, 34 etc, and is the equivalent of your fibo.c, though with the, possibly redundant, 'else' left in ...
[email protected]:~/swift $ cat fibo.swift
func fibonacci(n: Int) -> Int {
    if n < 2 {
        return n
    } else {
        return fibonacci(n:n - 1) + fibonacci(n:n - 2)
for n in 0...9 {
  print("Fibo(\(n)) = \(fibonacci(n:n))")
[email protected]:~/swift $ ./usr/bin/swift fibo.swift
Fibo(0) = 0
Fibo(1) = 1
Fibo(2) = 1
Fibo(3) = 2
Fibo(4) = 3
Fibo(5) = 5
Fibo(6) = 8
Fibo(7) = 13
Fibo(8) = 21
Fibo(9) = 34
