Page 1 of 2
programming with c#
Posted: Fri Oct 11, 2019 6:48 am
by est3
hi
i want to build a program to raspberry zero, with raspebian, but i know only c#... i can learn python if there is no other way, but i not wanna do that because it take me a lot of time, and i don't have time...
so, there is a way that i can program with c#?
the performance is very importent to me, beacause i need to read data from some (40+-) yk-04 mudels, by shift register, and the program working with time too, so i need something that work good.
Re: programming with c#
Posted: Fri Oct 11, 2019 9:10 am
by scruss
You can install a Mono (= portable .Net) development system with:
sudo aptinstall mono-complete
but whether there's a good and useful GPIO library for it, I don't know.
If the YK-04s you mention are those simple 4 Channel RF Remote Control Module with four buttons, you may hit some problems. I've used these before, and they've got no security or channel functions. Press 1 on one remote, and all of your receivers will register 1. I suspect this is not what you'd want. If it is what you want, you won't need a shift register: one receiver and 4 GPIO ports will read all of your remotes, but can't tell which one was pressed.
Posted: Fri Oct 11, 2019 9:44 am
by jahboater
Did you know that C++ is included as standard with Raspian?
There's no need to use Python or install mono etc.
C++ will be very very fast and has great support for the GPIO.
Posted: Fri Oct 11, 2019 10:34 am
by B.Goode
OP @est3 mentions three times that they want to program in C#. Ref: https://docs.microsoft.com/en-us/dotnet ... troduction
So a genuine question: At what point of sophistication does C# diverge sufficiently from 'classic' C or C++ that it becomes impossible to compile and run code with the standard GCC compiler for Linux?
Posted: Fri Oct 11, 2019 11:34 am
by Heater
est3,
This is confusing. In your other post you ask the same question but using Python. So which is it C# or Python?
I have no idea about the speed requirements for your project but if speed "bit-banging" a hardware interface is a concern neither C# or Python are suitable.
Posted: Fri Oct 11, 2019 11:44 am
by Heater
B.Goode,
I'm pretty sure it's impossible to compile any C# with both a C# compiler and a C++ compiler with out modification. Perhaps one can contrive an example. C is right out.
However I recently translated a couple of thousand lines of C# to to C++. That code did a lot of bit and byte twiddling on a proprietary binary format to extract data into useful structures and hence human readable messages in JSON. I know almost nothing about C# but this went very easily and quickly.
So I imagine a C# programmer could pick up enough C++ to get started quite well. Especially if they are introduced to modern C++ features and are not started off by basically learning C first as is traditional in many places.
On the other hand, I have no idea where a C++ neophyte would find such an introduction...
Posted: Sat Oct 12, 2019 5:44 pm
by ejolson
B.Goode,
It's much easier to translate a language that you don't know well into one that you do, even with programming languages.
My experiments with Mono and Visual Basic on a Raspberry Pi led to results that performed reasonably well. As the development of Mono is now sponsored by Microsoft, it is less likely a Java-style lawsuit will require royalty payments to Oracle for use of the API.
When it comes to very low-level GPIO interfacing, some assembler or C might be needed. That type of library code is generally quite small compared to the rest of the program; however, I would not know how to write such a library that could be used from C#. I wonder if one already exists?
Posted: Sat Oct 12, 2019 10:54 pm
by Heater
I think I would have a very hard time translating any non-trivial Forth or Smalltalk to C. Or even from class and template heavy C++ to C. I once worked for nearly two years on reimplementing an Intel x86 assembler project in C. Which was, shall we say, interesting given the total lack of documentation and the very few comments in the source being in Swedish.
That C# to C++ translation I mentioned was a walk in the park by comparison, it has similar types, similar control constructs, similar syntax etc. Just copy it into a .cpp file and massage it till it compiles properly.
I agree, better to stay away from anything Java or anything tainted by Oracle.
Posted: Sat Oct 12, 2019 11:22 pm
by est3
thanks a lot to all of you.
the mono know only build the progrem or it's can play a program that i devlop with VS?
you right, by default the yk-04 is with not address so press on button in one remote will be registe on all reciver, but this board use in the pair pt2262/72, they have tri-state pin address to pair transpition and reciver, so if i will weld (i hope this is the word for connect two object by tin in english) the same pins address in any pair remote and reciver they will be pair and press on button in one remote will register in one reciver only.
Posted: Sat Oct 12, 2019 11:31 pm
by est3
est3,
right now i try to working with python and because of it i asked about python, but it's hard to me, i'm not know the language, so in the while i try to find way to devlop on c#.
Posted: Sat Oct 12, 2019 11:41 pm
by est3
so what is the beter idea, try to convert to c++ or devlop with mono?
Posted: Sat Oct 12, 2019 11:49 pm
by jahboater
You will find C++ much more familiar!
Posted: Sun Oct 13, 2019 12:08 am
by est3
right, but i need also GUI and it's not sound easy with c++.
Posted: Sun Oct 13, 2019 4:05 pm
by scruss
Not if you've only used C#, as the OP stated.
I don't know of any GUI for Raspberry Pi that would replicate the Windows C# development experience.
Posted: Sun Oct 13, 2019 4:29 pm
by jahboater
He also mentioned Python as an alternative.
I think C++ is closer in style to C# than Python is.
Posted: Sun Oct 13, 2019 4:36 pm
by ejolson
Isn't Visual Studio Code running on the Pi similar? I understand it can even send telemetry data to Microsoft.
Posted: Sun Oct 13, 2019 5:50 pm
by Heater
ejolson,
From reports around here, yes.
Indeed it can.
But Microsoft is my friend. They gave me a new Surface Pro 4 when my old one exploded (No really, it did) even if it was well over it's two year warranty. They gave me Windows 10 for free to run on two nice PC's salvaged from the local university throw outs. They let me use Github for free for all my source repositories. They made the editor I use almost all day everyday, open source and for free. They fixed up their crappy operating system so that I can run all my favorite programs from Linux world. They give me free food and beer when I visit their developer parties. We have such a wild time. Such nice people.
But if it bothers anyone, VS Code Telemetry can be turned off easily enough: https://code.visualstudio.com/docs/getstarted/telemetry
Anyway, what has all that got to do with choice of programming language? I'm not sure if est3 meant to say "create a GUI" but VS Code won't help much with that.
Posted: Mon Oct 14, 2019 11:11 am
by hippy
Given you are familiar with C# and mono is easy to install ( and presumably to remove ); I would suggest installing mono and seeing for yourself if it is suitable for your needs.
If not then you can then consider how converting to C++ compares.
Posted: Tue Oct 15, 2019 7:16 pm
by est3
ok, thank you guys, you helped me a lot.
Posted: Wed Oct 16, 2019 7:27 am
by est3
hi, mono is just compleir that run on linux? or it compile the programso it can run on linux?
Posted: Wed Oct 16, 2019 7:39 am
by B.Goode
See the explanation here - https://www.mono-project.com/docs/about-mono/
Posted: Wed Oct 16, 2019 11:46 am
by est3
Mono, the open source development platform based on the .NET Framework, allows developers to build cross-platform applications with improved developer productivity.
It's mean that the program will be cross-platform, right? so i can develop in VS in windows (just for my convenience), compile with mono and run on raspbian, right?
Posted: Wed Oct 16, 2019 11:49 am
by B.Goode
It doesn't say that, but you might be right...
Why not try it and see, and report back what you find?
Posted: Wed Oct 16, 2019 2:23 pm
by ejolson
The language is the same as are many of the support libraries; however, there are some libraries on Windows which either are missing or incomplete under Mono. For this reason one needs to be very careful when creating a cross-platform program written in C# under Windows.
An approach more likely to succeed is to write the program on the Pi and and then run it on Windows. Note that once you get familiar with what libraries work well on both platforms, developing on Windows should be pretty easy too.
Posted: Thu Oct 17, 2019 9:48 am
by est3
thank you to both of you (:
