ScriptBasic
Re: General language discussion.
Sat May 18, 2019 12:02 am
Just Heater hogwash. :roll:
hippy
Sat May 18, 2019 12:30 am
Why are we back onto the "fibo() challenge" and "my preferred language is better than your preferred language" battles ???
ScriptBasic
Sat May 18, 2019 12:41 am
@hippy,
@Heater said that JavaScript runs circles around ScriptBasic which is false and misleading.
Here is the JaveScript version written in ScriptBasic which actual gives a better time.
FUNCTION fibonacci(num)
  a = 1
  b = 0
  FOR i = 1 TO num
    temp = a
    a += b
    b = temp
  NEXT
  fibonacci = b
END FUNCTION
PRINT FORMAT("%.0f\n",fibonacci(87))
Output
[email protected]:~/sbrpi/examples $ time scriba fibo_.sb
679891637638612224
real	0m0.014s
user	0m0.013s
sys	0m0.001s
ScriptBasic
Sat May 18, 2019 1:24 am
I was incorrect with the 87 value and meant 78.
Here are the results of ScriptBasic native and gmp versions and the Javascript version which still can't produce a correct answer at 78.
SB GMP
DECLARE SUB fibo ALIAS "fibo" LIB "gmp"
PRINT fibo(78),"\n"
 $ time scriba fibogmp.sb
8944394323791464
real	0m0.005s
user	0m0.005s
sys	0m0.000s
SB Native
FUNCTION sfibo (n)
        IF n < 2 THEN
                sfibo = 1
        ELSE
                m = 0
                p = 1
                q = 0
                FOR i = 2 TO n
                        m = p + q
                        q = p
                        p = m
                NEXT i
                sfibo = m
        END IF
END FUNCTION
PRINT FORMAT("%.0f",sfibo(78)),"\n"
$ time scriba fibo78.sb
8944394323791464
real	0m0.006s
user	0m0.006s
sys	0m0.000s
JavaScript via Node.js
function fibonacci(num){
  var a = 1, b = 0, temp;
  while (num >= 0){
    temp = a;
    a = a + b;
    b = temp;
    num--;
  return b;
console.log(fibonacci(78));
$ time node fibonacci.js
14472334024676220
real	0m0.784s
user	0m0.734s
sys	0m0.052s
Note: The above tests were run on my Ubuntu 64 bit laptop.
jahboater
Sat May 18, 2019 5:49 am
Fibo(78) requires 53 bits for the answer and JS stores normal ints in a binary64 float.
Sat May 18, 2019 6:01 am
jahboater,
That is right.
Turns out that fibo(78) is the biggest Fibonacci number JS can get right before having to change to using the BigInt type.
When ScriptBasic fixes the bug in his JS and gets the right result we might see that! :)
ScriptBasic
Sat May 18, 2019 6:07 am
I'm still waiting for that JavaScript code you ran that runs circles around ScriptBasic. What I posted was something I found on web. The Quite BASIC JavaScript Fibo has the same issue.
New Challenge
Write a JavaScript Fibonacci(78) that will produce the correct answer.
8944394323791464
Sat May 18, 2019 7:09 am
Heater,
No, I did not.
I was simply referring to your very own comments re: the speed of ScriptBasic for the fibo(4784969) challenge. You said it was so slow you would not want to run it again.
I already gave you that code just a few posts back https://www.raspberrypi.org/forums/view ... 5#p1469506
Micro-benchmarking like this is very tedious and often futile but as you asked let's do it properly...
The attached tar file contains the following:
fiboIter: - Your schoolboy solution (With bug fixed)
fibo - My original big integer version based on the maths I found here: https://www.nayuki.io/page/fast-fibonacci-algorithms
fiboFast - Derived by me from Paeryn's Haskell solution.
fiboFaster - Derived by me from ejolson's fibogmp solution.
I also adapted the benchmarking code to run all of these for fibo(78) one hundred times. Printing the result and execution time of each run. Like so:
function timeIt (f, k) {
  t = new Date()
  res = f(k)
  dur = new Date() - t
  console.log(f.name.padEnd(11, ' ') + res + " in " + dur + "ms")
let n = 78
for (let i = 0; i < 100; i++) {
  timeIt(fiboIter, n)
  timeIt(fibo, n)
  timeIt(fiboFast, n)
  timeIt(fiboFaster, n)
With the following results on my old Intel i7 2600K 3.4GHz PC.
$ time node fibo.js
fiboIter   8944394323791464 in 0ms
fiboFast   8944394323791464 in 2ms
fiboFaster 8944394323791464 in 0ms
fibo       8944394323791464 in 0ms
fiboFast   8944394323791464 in 0ms
real    0m0.272s
user    0m0.094s
sys     0m0.141s
Here we see that all the fibo versions are too fast to time at 1ms resolution.
In aggregate we have 0.272s / 400 as the average run time for each fibo = 0.68 milliseconds.
But wait... That is wall clock time. The actual CPU time is only 0.094s or 0.2 milliseconds per fibo.
I suspect it's likely that ScriptBasic is right, JS runs rings around ScriptBasic.
I was tempted to get ScriptBasic installed and compare but I can find location of it's source code that works.
fibo.js.tgz
(1003 Bytes) Downloaded 11 times
Sat May 18, 2019 7:13 am
ScriptBasic,
New Challenge
8944394323791464
This is getting silly. How many times during our discussions do I have to link you to the fibo challenge repository which has had working solutions in JS and many other languages for weeks and weeks now?
https://github.com/ZiCog/fibo_4784969
Can we move on to some more interesting general language discussion in the spirit of this thread?
Sat May 18, 2019 7:14 am
We don't have many rules around but one is be good to each other.
If I get one more report about your posts you will get permabanned. I simply do not have time to deal with the amount of reports your posts engender.
And keep on topic.
ScriptBasic
Sat May 18, 2019 7:17 am
The ScriptBasic version of the JavaScript Fibo(78) produces the correct answer. Looks like it's JavaScript not the code that has the issue.
  a = 1
  b = 0
  FOR i = 1 TO num
    temp = a
    a += b
    b = temp
  NEXT
  fibonacci = b
END FUNCTION
PRINT FORMAT("%.0f\n",fibonacci(78))
[email protected]:~/sb/examples/test$ time scriba fibo_js.sb
8944394323791464
real	0m0.023s
user	0m0.004s
sys	0m0.003s
ScriptBasic
Sat May 18, 2019 7:30 am
Heater wrote: I was tempted to get ScriptBasic installed and compare but I can find location of it's source code that works.
ScriptBasic Resources
ScriptBasic
Sat May 18, 2019 7:37 am
JamesH wrote: We don't have many rules around but one is be good to each other.
Please explain good to each other. It's okay to criticizes an make false claims about software you never tried but when calling someone on it will get you ban? Sounds like the whinner's are the winners on this forum.
Sat May 18, 2019 7:41 am
Be serious. It's your Javascript Foo that is failing you here.
This works:
That is part 1...
Sat May 18, 2019 7:47 am
Part 2:
No seriously.
Concatenate the above two code blocks and you have a valid Javascript fibo(78) program.
$ cat fibo_00 fibo_01 > fiboTemp.js
$ time node fiboTemp.js
8944394323791464
real    0m0.250s
user    0m0.125s
sys     0m0.078s
ScriptBasic
Sat May 18, 2019 7:53 am
That is your fibo(78) JavaScript solution?
I already proved the code I posted is error free.
You need to do better.
Sat May 18, 2019 8:00 am
ScriptBasic,
The fibo(78) in Javascript you posted is not error free. It has a bug and produces the wrong result. It's not me that needs to do better with that.
How many times do I need to point you to the repo that contains the working code you ask for. I also attached it here in a couple of posts back: https://www.raspberrypi.org/forums/post ... #pr1469580
That gobbledy gook I posted above is actually a working program that produces fibo(78). It is derived from this:
function fiboIter(num){
  while (num-- > 0) {
    temp = a;
    a = a + b;
    b = temp;
  return b;
console.log(fiboIter(78))
Now. I'm having trouble getting ScriptBasic:
$ git clone [email protected]:scriptbasic/sb-dev.git
Cloning into 'sb-dev'...
Permission denied (publickey,gssapi-keyex,gssapi-with-mic).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
$ git clone https://sandbox.allbasic.info/scriptbasic/sb-dev.git
fatal: repository 'https://sandbox.allbasic.info/scriptbasic/sb-dev.git/' not found
ScriptBasic
Sat May 18, 2019 8:12 am
This is what the resources post says. Not sure where you got your link.
The source can be found in the AllBASIC sandbox.
https://sandbox.allbasic.info:8181/scri ... ee/cleanup
jalih
Sat May 18, 2019 8:20 am
Can we just move on? This particular task is too fast to be used as any kind of real benchmark. I ran this 1000 times inside a loop and average execution time was less than millisec, when tested with 8th programming language.
It's a fact that node's optimizer is especially good and performance is more than adequate for most programming jobs.
ScriptBasic
Sat May 18, 2019 8:24 am
I could care how fast or slow it is, I just want to see a correct answer using the code I know works in JavaScript. Why are you ignoring the problem?
Sat May 18, 2019 8:28 am
ScriptBasic,
What problem?
I saw a problem. I told already how to fix it. Let me reiterate:
The ScriptBasic version of the JavaScript code runs flawlessly but fails in JavaScript.
I don't understand what you are trying to say there.
The Javascript version you posted here: https://www.raspberrypi.org/forums/view ... 8#p1469529 is buggy and produces the wrong result.
I fixed it for you and posted it above. Now it produces the correct result.
$ cat fiboTemp.js
  while (num-- > 0) {
    temp = a;
    a = a + b;
    b = temp;
  return b;
$ node fiboTemp.js
8944394323791464
By the way: The ScriptBasic you posted there is also buggy. It will produce fibo(0) = 1. It is a totally different algorithm to your JS version anyway, so the one says nothing about the other.
I don't want to register for anything to get the code.
ScriptBasic
Sat May 18, 2019 8:35 am
Use the link posted in the quote from the resource post.
The resource page clearly gives the correct link to the ScripBasic repository.
I would suggest installing the runtime and after you get comfortable with the BASIC build it from source.
bensimmo
Sat May 18, 2019 9:23 am
It would be nice if the fibo(big number) and fibo(pointlessly small number) challenge and talk was contained in their own topics, so nobody else has to wade through it all
It's now scattered in to yet another, could have been interesting thread).
I might start actually reporting threads ((other than spam) and just report them all as [mod removed a fair but rude statement here]).
Sat May 18, 2019 9:31 am
bensimmo,
You are right.
I should have started a fibo challenge thread of it's own ages ago. Sadly I did not. That silly thing spawned a lot of interesting discussion about all kind of programming languages and how the get along with the Pi. Programming styles and so on.
I'll want to open Fibonacci challenge thread. Mostly to wrap it all up and point to the repo containing the solutions. First I have to be sure I can run them all on a Pi. I have done some but not all.
bensimmo
Sat May 18, 2019 9:44 am
I don't mind the challenge of either the pointless small or nice and large fibo. It's just the constant match between the two of you in every thread that has any inclination to programming or numbers.
Start a topic and keep the challenge going, you don't even need to wrap it up, especially if another language crops up.
Is there a complete Scratch one yet or Node Red implementation.
Or Bosque
Get back to other random pointless but interesting languages here :-D. Like Bosque?
