John_Spikowski
Re: ScriptBasic
Sun Jun 23, 2019 3:19 am
I'm running Gitlab CE hosted on a Amazon EC2 instance.
John_Spikowski
Re: ScriptBasic
Sun Jun 23, 2019 3:47 am
@Paeryn,
Since you seem to feel comfortable under the ScriptBasic covers, maybe you can give me a hand with COMMANDs.. SB reserves a set of operator pairs to be used by extension modules. I would like to replace the GMP functions with DECLARE COMMAND. Here is an example for GMP2 add.
 Operators that are undefined by default but can be used by external modules are:
[email protected]    -^    -<    ->    -?    -=    -*    -/    -%    -!    -#    -&    -\    -`
-'    [email protected]    ^^    ^<    ^>    ^?    ^=    ^*    ^/    ^%    ^!    ^#    ^&    ^\
?`    ?'    [email protected]    =^    =<    =>    =?    ==    =*    =/    =%    =!    =#    =&
=\    =`    ='    [email protected]    *^    *<    *>    *?    *=    **    */    *%    *!    *#
!%    !!    !#    !&    !\    !`    !'    [email protected]    #^    #<    #>    #?    #=    #*
Current:
c = GMP2::add(a, b)
Wishlist:
c = a +! b
+! Is the COMMAND name and a and b are arguments. The IFF COMMAND in the trial extension module is an example of this feature of SB.
Try the wishlist syntax in SB. The message returned Is a clue.
(0): error &H1c:Command is not implemented and no currently loaded extension module defined behaviour for it
I think command.c is a good place to start.
Airr
Re: ScriptBasic
Sun Jun 23, 2019 5:27 am
IFF syntax in SB is:
IF a THEN a = IFF(a>1,1,-1)
So I don't think it's a good example of what you want.
Also, what you're asking for isn't as clear (as far as it being an extension module function) as what we currently have.
John_Spikowski
Re: ScriptBasic
Sun Jun 23, 2019 6:14 am
Once we figure this gem out, it's going to open up a whole new level of extensions,.
John_Spikowski
Re: ScriptBasic
Sun Jun 23, 2019 6:22 am
My test of IFF segfaults.
INCLUDE trial.bas
a = 5
IF a THEN a = IFF(a>1, 1, -1)
PRINT a,"\n"
[email protected]:~/sb/GMP$ scriba cmdtest.sb
The function bootmodu was started and the requested version is 11
The variation is: STANDARD
We are returning accepted version 11
The function bootmodu was started.
Segmentation fault (core dumped)
This works.
DECLARE COMMAND  IFF  ALIAS  "iff"  LIB  "trial"
a = 5
a = IFF(a > 1, TRUE, FALSE)
PRINT a,"\n"
-1
The function finimodu was started.
To get the maximum benefit from COMMANDs one should INCLUDE the DECLARE COMMAND and not make it part of a MODULE.
John_Spikowski
Re: ScriptBasic Sandbox
Mon Jun 24, 2019 3:48 am
If you would like to participate in the ScriptBasic project from reporting issues to correcting and enhancing source, send me an email to [email protected] with ScriptBasic in the subject and I will setup an account in the sandbox based on your role. A guest role in most cases is sufficient.
John_Spikowski
Re: ScriptBasic
Mon Jun 24, 2019 6:15 am
A project on the table is converting ScriptBasic's build system documentation from source to HTML to creating markdown documentation instead. Another option is to embed markdown docs in source. (easier to parse)
Re: ScriptBasic
Mon Jun 24, 2019 7:11 am
ScriptBasic,
In reply to you questions on the Fibonacci thread:
Once again I present codes and results demonstrating memory leaks in ScriptBasic and the GMP2 extension. See below.
I can call the GMP fibo() function in loop with no memory runaway. (user created buffer)
Please show your code because I cannot. See below.
There is noise on the web about GMP leaking string responses or not being properly cleared.
No, there is not. Unless you can provide a link.
Your C version works so go figure. You have tried running that In a loop, correct?
Yes it does. The following C code was my suggested style to do big numbers with GMP in ScriptBasic. It runs forever in a loop.
Provided ScriptBasic would do all the same inits, clears and frees it would also be memory leak free.
integer_strings.c
// An experiment in doing integer arithmetic using GMP with all numbers represented by strings.
// By heater.
// Modified June 11, 2019 to use base 32 strings for intermediate results.
#include <gmp.h>
#include <string.h>
#include "integer_strings.h"
// Functions letis, addis, subis and mulis do large integer arithmetic on integers represented by strings.
// WARNING: Not thread safe due to use of global op1, op2, res.
static mpz_t op1;
static mpz_t op2;
static mpz_t res;
char* is_base(const char *s, int base) {
    mpz_set_str (op1, s, IS_BASE);
    char* res_string = mpz_get_str (0, base, op1);
    return res_string;
char* is_let(const char* s) {
    return strdup(s);
char* is_add(const char* s1, const char* s2) {
    mpz_set_str (op1, s1, IS_BASE);
    mpz_set_str (op2, s2, IS_BASE);
    mpz_add (res, op1, op2);  // result = x * y
    char* res_string = mpz_get_str (0, IS_BASE, res);
    return res_string;
char* is_sub(const char* s1, const char* s2) {
    mpz_sub (res, op1, op2);  // result = x * y
    return res_string;
char* is_mul(const char* s1, const char* s2) {
    mpz_mul (res, op1, op2);  // result = x * y
    return res_string;
void is_init() {
    mpz_init(op1);
    mpz_init(op2);
    mpz_init(res);
void is_clear() {
    mpz_clear(op1);
    mpz_clear(op2);
    mpz_clear(res);
fibo_strings.c
// By heater.
#include <stdio.h>
#include <stdlib.h>
char* fibos[3];
// Return the n'th Fibonacci number as a decimal string for integer n
char* fibo (int n) {
    char* res;
    if (n <= 2) {
        return is_let(fibos[n]);
    int k = (n / 2);
    char* fk = fibo(k);
    char* fk1 = fibo(k + 1);
    char* a;
    char* b;
    if ((n % 2) == 0) {
        a = is_add(fk1, fk1);
        b = is_sub(a, fk);
        res = is_mul(fk, b);
    } else {
        a = is_mul(fk, fk);
        b = is_mul(fk1, fk1);
        res = is_add(a, b);
    free(a);
    free(b);
    free(fk);
    free(fk1);
    return res;
int main(int argc, char* argv[]) {
    int n = 4784969;               // The first Fibonacci number with a million digits
    if (argc >= 2) {
        n = atoi(argv[1]);
    is_init();
    fibos[0] = is_let("0");
    fibos[1] = is_let("1");
    fibos[2] = is_let("1");
    int count = 0;
    while (1) {
        char* f = fibo(n);
        char* f10 = is_base(f, 10);
        puts(f10);
        printf("%d\n", count);
        free(f10);
        free(f);
        count++;
    free(fibos[0]);
    free(fibos[1]);
    free(fibos[2]);
    is_clear();
    return (0);
Result: fibo_strings runs forever on my 8GB memory PC with top only showing 0% memory consumption.
1milfibo.sb
import gmp2.bas
function fibo(n)
    a = 1
    b = 0
    p = 0
    q = 1
    while n > 0
        if (n % 2) = 0 then
            psq   = gmp2::mul(p, p)
            qsq   = gmp2::mul(q, q)
            twopq = gmp2::mul(p, q)
            twopq = gmp2::mul_si(twopq, 2)
            p     = gmp2::add(psq, qsq)
            q     = gmp2::add(twopq, qsq)
            n = n / 2
        else
            bq    = gmp2::mul(b, q)
            aq    = gmp2::mul(a, q)
            ap    = gmp2::mul(a, p)
            bp    = gmp2::mul(b, p)
            a     = gmp2::add(bq, aq)
            a     = gmp2::add(a, ap)
            b     = gmp2::add(bp, aq)
            fibo  = b
            n = n - 1
        end if
    wend
end function
count = 0
while 1
    f = fibo(4784969)
    count = count + 1
    print f,"\n"
    print "Count: ", count,"\n"
wend
Result: 1milfibo.sb runs for 574 iterations on my 8GB memory PC before segfaulting. Last I checked before the segfault memory use was over 66% according to top.
$ scriba  1milfibo.sb
74615715617623206204585291487968755147324883784916338945806361951766313865956891695455563801462249978567353436540666740580717167763216988216644330074030719891463180149736853685001275152076875379936330930391815964864885353407167474856539211500699706378405156269
Count: 574
hfibo.sb
import gmp2.bas
function hfibo(n)
  local a, b, fk, fk1, k, r
  SPLIT "0,0,0,0,0,0" BY "," TO k, a, b, r, fk, fk1
  if n = 0 then
    r = 0
  else if n <= 2 then
    r = 1
  else
    k = (n / 2) OR 0
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if (n and 1) = 0 then
      a = gmp2::add(fk1, fk1)
      b = gmp2::sub(a, fk)
      r = gmp2::mul(fk, b)
    else
      a = gmp2::mul(fk, fk)
      b = gmp2::mul(fk1, fk1)
      r = gmp2::add(a, b)
    end if
  end if
  hfibo = r
end function
count = 0
while 1
    f = hfibo(4784969)
    count = count + 1
    print f,"\n"
wend
Result: hfibo.sb runs for 12 iterations on my 8GB memory PC before segfaulting. Last I checked before the segfault memory use was over 68% according to top.
Count: 12
John_Spikowski
Re: ScriptBasic
Mon Jun 24, 2019 7:22 am
The GMP2 extension module source is in the sandbox. The fibo() function is included.
I would be thrilled if you could get the GMP2 module working like your C version. Call it GMP3. 8-)
Re: ScriptBasic
Mon Jun 24, 2019 7:47 am
ScriptBasic,
Yes I know. It's horrible.
 res = mpz_get_str(NULL,10,g_Res);
 besSET_RETURN_STRING(res);
 free(res);
Looks like strings returned from mpz are being freed correctly.
I have idea what happens to the copy of the string after it has been eaten by besSET_RETURN_STRING. And life is too short to find out.
Not going to happen. Too many other fish frying around here.
In don't think the ScriptBasic big number extension should be called "GMP" anything. It implements big integers and should say that. Who cares how they are implemented under the hood. What happens if you want to change from GMP to some other big number library?
John_Spikowski
Re: ScriptBasic
Mon Jun 24, 2019 8:09 am
You would create another BIGINT extension module.
Re: ScriptBasic
Mon Jun 24, 2019 9:19 am
ScriptBasic,
No doubt.
But then it would have a different name and perhaps different method names and perhaps not work the same way. To make us of it one would have to rewrite all ones code to use HEATER::PLUS...(say) instead of GMP2::ADD and so on.
Or it would have the same name, but that would be confusing, and at that point you start to realize why a big integer, or any other module, should be named after what it does, not how it's implemented. We are working in a high level language, right?
Weave
Re: ScriptBasic
Mon Jun 24, 2019 4:24 pm
ScriptBasic wrote:
Thu May 09, 2019 5:26 pm
ScriptBasic is my replacement for bash.
BaCon comes in a version written in bash and a version written in itself. I think @ejolson posted a script showing bash being 30 times slower than ScriptBasic.
I think this is rather misleading, BaCon is a BASIC to C converter, only the conversion happens in bash then you end up with a native executable.
John_Spikowski
Re: ScriptBasic
Mon Jun 24, 2019 4:42 pm
You're probably the best person to resolve this GMP issue but it's impossible to get you to engage. (someone else's problem)
Glad to hear ScriptBasic isn't alone on this issue and has bitten you as well.
John_Spikowski
Re: ScriptBasic
Wed Jun 26, 2019 5:35 am
When you are ready to distribute your ScriptBasic applications you have the option to compile your scripts to C. The hello executable is 13.5 KB. Requires latest source that fixed the -C output source file. (latest scriba)
hello.sb
PRINT "Hello World!\n"
[email protected]:~/sbrt/2c $ scriba -Co hello.c hello.sb
[email protected]:~/sbrt/2c $ gcc -Os hello.c ./stndlone.o ./libscriba.so -o hello
[email protected]:~/sbrt/2c $ ./hello
Hello World!
[email protected]:~/sbrt/2c $ ls -l hello
-rwxr-xr-x 1 pi pi 13528 Jun 25 22:20 hello
[email protected]:~/sbrt/2c $ gcc hw.c -o hw
[email protected]:~/sbrt/2c $ ./hw
Hello World!
[email protected]:~/sbrt/2c $ ls -l hw
-rwxr-xr-x 1 pi pi 8144 Jun 25 22:54 hw
[email protected]:~/sbrt/2c $ cat hw.c
#include <stdio.h>
int main()
    printf("Hello World!\n");
    return 0;
hippy
Re: ScriptBasic
Wed Jun 26, 2019 9:46 am
That "compile your scripts to C" is somewhat misleading. What one can do is combine the ScriptBasic interpreter with a script's virtual object code to create a single executable, and this is achieved through creating a C file which then needs to be compiled.
"Compile to C" would normally be taken to mean "convert every script line to its equivalent C". This is not what ScriptBasic provides for. It is more bundling the interpreter with the script's object code to create a single native executable.
It would be better to say "When you are ready to distribute your ScriptBasic applications you have the option to turn that into a single executable".
RichardRussell
Re: ScriptBasic
Wed Jun 26, 2019 10:50 am
Odd. BBC BASIC (for Windows) makes its 'executables' in the same way: it binds a copy of the run-time-engine and a compressed version of the BASIC program (and any libraries and resources it needs) into a single file. But it does that without any recourse to C or 'compiling' anything, indeed it's pretty much achieved simply by concatenating the various components and adding a simple 'directory' pointing to where they are in the file. Using a C compiler and linker to do the same job sounds like overkill (one can't assume such tools will be available in Windows).
hippy
Re: ScriptBasic
Wed Jun 26, 2019 12:24 pm
I would guess it side-steps any issues which may arise through simple concatenation, or needing to have a complicated concatenation scheme within the ScriptBasic compiler which may have to differ depending on platform.
It would make sense though to provide concatenation where that works and revert to something else only when that doesn't but, on the other hand, having one scheme is easier than having multiple.
It's a good point about needing a C compiler though; I don't have one on any of my Windows machines.
Converting to an executable isn't really necessary under Linux anyway; one can simply add an appropriate shebang and set the file's execute permission, exactly the same as one can do it for Python and other scripting languages -
#!/usr/local/bin/scriba
ScriptBasic does ignore the shebang when added and scriba handles ScriptBasic programs without extensions.
On Windows one would normally create a batch file which can invoke an interpreter as that is rarely problematic.
John_Spikowski
Re: ScriptBasic
Wed Jun 26, 2019 3:08 pm
If you don't want to mess with a C compiler, you can still create a standalone executable.
scriba -Eo hello.exe hello.sb
This appends a binary form of the script to a copy of scriba with the name given.
Scriba always checks to see if a script is attached or not before processing the command line. You can still pass user command line arguments. Just no - options.
Under Linux, you need to use the full path for scriba for this command to work.
Last edited by John_Spikowski on Wed Jun 26, 2019 6:50 pm, edited 3 times in total.
RichardRussell
Re: ScriptBasic
Wed Jun 26, 2019 4:07 pm
Oh, right, so when is the 'C' approach preferable?
John_Spikowski
Re: ScriptBasic
Wed Jun 26, 2019 4:10 pm
When you want to run scriba as a common shared object with a bunch of scripts as small footprint executables.
John_Spikowski
Re: ScriptBasic
Wed Jun 26, 2019 7:33 pm
@scruss,
I just noticed you're a member of the AllBasic. info forum. Cool! We would enjoy your input and feedback there.
John_Spikowski
Re: ScriptBasic
Wed Jun 26, 2019 7:43 pm
Would you like to report issues and submit merge requests to the ScriptBasic development sandbox repository? It's easy with no commitment. Just create a project guest account. This project is where it is today due to talented developers like yourself doing their part to make the language better and more user friendly to a wider audience.
Send an email to [email protected] with your preferred user ID and I will setup a guest membership account for you. It would be helpful due to all the spam I get to put SCRIPTBASIC in the subject title so I don't miss your request.
scruss
Re: ScriptBasic
Wed Jun 26, 2019 11:29 pm
You really, really don't want my code contributions, though …
John_Spikowski
Re: ScriptBasic
Mon Jul 01, 2019 12:15 am
I found a cool open source GPIO data analyzer.
Panalyzer
This is a Logic Analyzer that runs on the RaspberryPi. The basic idea is that it disables interrupts for a period, while sampling the GPIO pins once a microsecond. It then re-enables interupts and displays traces showing what the relevant GPIO pins were doing. Clearly the RaspberryPi is frozen while data is being gathered, because interrupts are disabled, but a timeout is implemented to avoid hanging for ever if a trigger word is not seen. Panalyzer has features such as specifying trigger patterns, buffer depth, a pair of cursors for measuring time periods on the trace, etc. In the display you can click and drag across part of the trace to zoom in on that section.
