doubleudee1
Reading Filenames into an array
Thu Mar 21, 2019 12:23 pm
I have this script from a site that i thought would work, that I altered to suit, but I am getting an error '-bash: ./: Is a directory'
#!/bin/bash
SOURCE_DIR=/home/pi/CCTV/RearOfHouse/TestDirs/
files=(
   "$SOURCE_DIR"/*.jpg
   "$SOURCE_DIR"/*.mp4
   "$SOURCE_DIR"/**/*
printf '%s\n' "${files[@]}" # i.e. path/to/source/filename.jpg
printf '%s\n' "${files[@]##*/}" # i.e. filename.mp4
#ERROR+ -bash: ./: Is a directory
Still learning the basics of coding here, can anyone help please?
WD
Make the most of your family and friends , your children grow up too quickly and you don't notice yourself ageing, friends dissapearing, moving on. You make plans for your future, but they can all be smashed in an instant, live life and enjoy. :)
topguy
Re: Reading Filenames into an array
Thu Mar 21, 2019 12:33 pm
And the error doesnt report any specific line number ?
Do the error go away if you remove:
"$SOURCE_DIR"/**/*
doubleudee1
Thu Mar 21, 2019 12:44 pm
"$SOURCE_DIR"/**/*
No, I've tried commening out that line and I still get the same error?
B.Goode
Thu Mar 21, 2019 2:18 pm
As an overall approach, as with conventional programming languages, lots of intermediate snapshots of the state of your variables might help? I think that in the bash shell the echo command might be the tool to use.
But, unverified, here is something to check out -
You have
So the directory path terminates with "/"
Then you prepend it to a file path
"$SOURCE_DIR"/*.jpg
Question: does that result in an unexpected "//" in the resulting string. Is that valid in the context where you try to use that result?
doubleudee1
Thu Mar 21, 2019 2:30 pm
You have
"$SOURCE_DIR"/*.jpg
sorry, same result using your suggested code
B.Goode
Thu Mar 21, 2019 2:35 pm
I didn't suggest any code...
If you have an error, share the code and the full text of any resulting error message.
doubleudee1
Thu Mar 21, 2019 2:59 pm
###########################CODE1
#!/bin/bash
SOURCE_DIR=/home/pi/CCTV/RearOfHouse/TestDirs *.jpg
files=(
   "$SOURCE_DIR"/*.jpg
   "$SOURCE_DIR"/*.mp4
#   "$SOURCE_DIR"/**/*
##You can then use printf to see the contents of the array including paths:
#Or using parameter substitution to exclude the pathnames:
The only error I get when running the code is:-
Regards
WD
B.Goode
Thu Mar 21, 2019 3:10 pm
What do you type at the shell (command line) prompt to run your shell script?
doubleudee1
Thu Mar 21, 2019 3:29 pm
I put in :-
./ filename
from the same directory the file I created (above) exists in and then press enter
B.Goode
Thu Mar 21, 2019 3:33 pm
No space!
./filename
The script may need to be made executable first:
chmod +x filename
topguy
Thu Mar 21, 2019 3:48 pm
pi@raspberrypi:~ $ ./ gdgfdf
You really didnt see the connection ??
doubleudee1
Thu Mar 21, 2019 3:51 pm
No space!
./filename
chmod +x filename
Thanks, space taken out and file made executable, output now as expected: (except it doesn't like me declaring the type of file to look for)-
./CreateSecurityDirs: line 4: *.jpg: command not found
/*.jpg
/*.mp4
*.mp4
B.Goode
Thu Mar 21, 2019 4:03 pm
I see the same!
pi@RPi3BplusOffice:~ $ FRED=/home/pi  *.jpg
    -bash: *.jpg: command not found
What do you hope to achieve by the "*.jpg" part of that command - it looks superfluous, as proven by the possibility correct output that follows?
doubleudee1
Thu Mar 21, 2019 5:13 pm
I see the same!
Sorry, I added the .jpg thinking it would pull out only those, my next task is to see if I can pull out a section/clip of the file, i.e. starting at point 3 and pull out the next 3 chars.
Many thanks for everyone's help.
WD
B.Goode
Thu Mar 21, 2019 5:23 pm
You might find something like this helpful to understand the syntax of bash array indexing...
https://www.thegeekstuff.com/2010/06/ba ... y-tutorial
Nos da - Dewi. (David - also a proud and busy taid!)
